2005 won't start I'm stumped !
Like Tree2Likes
  • 2 Post By Tommy382
Old 23 Feb 2014, 06:21 pm
Exclamation 2005 won't start I'm stumped !
Working on pt for a friend. Turn the key and everything lights up as should. Time to start and just clicks. I can quick turn from on to start and eventually get it to turn over . I have searched this forum high and low and kind figure it out. What I have done...
Checked battery-good
Checked starter and solenoid- good
Checked all fuses and grounds and relays-good
I get over 12 volts to the starter from battery
I put a jump wire on the small wire that goes on the solenoid and put in the positive side of battery and starts right up.
I checked the volts in same small wire as it is turned from on to start. Only getting 3-4 volts I think. If I have someone quick start it from on to run it will eventually turn over and I get over 12 volts as need to the wire when it does turn over.
I pulled the ignition and actuator looks new.
I took the actuator out and turned the piece it connects too. No help
I have tried pulling the fog light fuse that others mentioned. Nothing !! Long story short I think but not sure, the problem is I'm not getting the 12 volts needed to the small wire that connects to the solenoid when I turn the key over to start.
I'm lost now
Thanks in advance for any help someone might lead me to source.
Old 23 Feb 2014, 09:46 pm
Default Re: 2005 won't start I'm stumped !
Update. The brown wire that hooks to the solenoid does not hold power when I turn to start. I hooked a test light too it and turned the key to start. It's lights up for just a sec and goes off. Comes on every time I turn the key to start then right back off. When I fast start it turning from on to start real quick , I can finally hold the key over and the light stays on while cranking. When I turn the key to start there should be constant 12 volts to the brown wire as long as have the key turned correct ? My next question would be why is it not? Still clueless. When I bump start it to the point that it will crank the 12 volts stays on as it should do.
Old 24 Feb 2014, 09:08 am
randyincctx's Avatar
Lightbulb Re: 2005 won't start I'm stumped !
Really sounds like a faulty ignition switch to me.....Test the contacts,and wiring to it with a multimeter,while turning the key/trying to start it,and you'll find the source of the problem.
Just because an ignition switch 'looks new' doesn't necessarily mean it's OK.
Aka:~KILLER~
Old 24 Feb 2014, 09:22 pm
I finally figured it out. This might help someone in the future. This all started cause the solenoid on the starter went bad like most others. But they don't make a replacement solenoid for a pt. so I took the starter off and had the solenoid replaced with the jeep solenoid that everyone recommends. Well the problem I figured out after tearing the whole car apart and checking every circuit is that the jeep solenoid has a slightly smaller connector where the brown wire snaps on with factory connector wire. So I bent the connector so it would be a tight fit. Problem solved. The good news is I know everything about the starter system now so if everyone had any questions lol. Thanks for the reply!!
Busted_PT and Logos85 like this.
Old 24 Feb 2014, 09:25 pm
Oh and one more trick I found. The ignition system has those t10 security screws on them. You can stick a very small flat head screwdriver in those and break off the small tit in the center of them and just use a regular t10. For those of us that don't have every specialty tool they make.
Old 25 Feb 2014, 09:47 am
Ray_Dockrey's Avatar
This probably would have been good info to have listed in your original post. Makes a difference when all the facts are given when diagnosing an issue.
Old 25 Feb 2014, 10:29 am
Thanks for the update on the repairs. For the security T10 . You can get a set of these at those cheap tool places and some flea markets. In case someone would rather get some. They fit in a magnetic screw driver.
Old 25 Feb 2014, 02:35 pm
Question Re: 2005 won't start I'm stumped !
Uh,yeah they do....You just have to know where to l@@k....
I still have this one saved in my Ebay 'Watch List',because I had a sticking solenoid plunger a couple of months ago,and figured if it kept on giving me problems I would replace it......But,mine loosened up after tapping on it with a hammer & stick.
Here's the listing on Ebay:
(notice it says 'Chrysler'?)Starter Solenoid Mazda MPV Chevrolet Suzuki Saab Subaru Chrysler | eBay
Aka:~KILLER~
Old 11 Mar 2014, 11:13 am
When replacing the Ignition switch, I assume you need to remove the MFS first ? Any special tricks remove/replace dealing with the back side of the key cylinder other than the security torx driver bit. I am still having the occasional no crank on my 2002 PT 5 spd. I have installed new starter,new battery, MFS, and going to replace the battery pos cable end at the starter also or maybe new cables (both). Thanks for info !
2005 PT Cruiser won!t start Rudydog Tech & Performance Forum 3 06 Jan 2014 06:45 pm
2005 Wouldn't start tcham Tech & Performance Forum 0 01 Jun 2013 04:29 pm
Please Help, 2005 Pt wont start lydia Tech & Performance Forum 4 30 Oct 2011 01:03 am
stumped! 01ptcruiser Tech & Performance Forum 2 09 Apr 2011 05:00 pm
2005 pt cruiser no start fusion1620 Tech & Performance Forum 1 17 Jun 2010 05:57 am
