01 Limited Edition Running too rich
Like Tree2Likes
  • 1 Post By pt06
  • 1 Post By Busted_PT
Old 23 Feb 2014, 09:55 pm
Unhappy 01 Limited Edition Running too rich
I have a 2001 PT cruiser limited edition 5spd manual with 47xxxx miles. I just recently replaced the old catalytic converter and both O2 sensors because of a PO420 code which set my check engine light off. I thought my issues were solved but now I've realized it's running rich because black smoke is still coming out the back at higher revs! Any help would be very appreciated!!!
Old 24 Feb 2014, 04:09 am
Default Re: 01 Limited Edition Running too rich
Jb; pcv valve? --- Vacuum leak [hoses] --- map sensor/wiring?
UptownSport likes this.
Old 24 Feb 2014, 08:06 am
Fuel treatment just in case. Then check the temp reading from diagnostic port. If it thinks it's running to cold It will richen the fuel mixture.
Old 24 Feb 2014, 08:27 pm
If this is the case, how could I change it?
Old 24 Feb 2014, 08:53 pm
Your IAT (Intake Air Temperature) sensor measures the air density. Make sure it's connected correctly and there's no outside air getting into the intake that would mess up the reading of the sensor.
Old 26 Feb 2014, 12:02 am
UptownSport's Avatar
Exhaust manifold will crack, but I'm not sure the oxygen sensor could even adjust computer far enough to make it run rich enough to make it burn black!
Check if all else fails?
idle off and running rich after 3"downpipe/bov installed ptcruiser94 General Turbo Discussions 3 26 Aug 2013 08:58 am
Limited Edition/GT theRickster General PT Cruiser Discussions 9 06 Apr 2013 05:39 pm
Running Rich? Ikster Tech & Performance Forum 3 05 May 2012 06:33 pm
'01 PT Limited Edition Won't Start susan General PT Cruiser Discussions 15 22 Oct 2011 09:57 am
01 limited edition or 03 GT? Dub General PT Cruiser Discussions 9 14 Dec 2010 08:34 pm
