Trouble Codes--Radiator
Old 24 Feb 2014, 09:04 am
Default Trouble Codes--Radiator
Yesterday my check engine light came on, here are the codes that it threw up. (Which I was soo proud that I was able to pull them up and figure them out!)
This is what I got:
0517-Battery over temp (I have gotten this code before, when my battery needed changed, it went away once it was replaced.
0128- radiator
Today I stopped at Napa and bought coolant for my car and topped it off. I asked the guy at nappa if I should take the radiator cap off and add some directly to it and he told me no, just add it to the radiator fluid tank. I drove around for about 10mins after I put the coolant in, and the temp gauge fluctuated between half way and the line below it, is that normal? What is your take on this issue?
If this doesn't fix the radiator issue how hard is it to replace it? Is it something a novice could do?
Thanks for any help!
Old 25 Feb 2014, 04:40 am
Default Re: Trouble Codes--Radiator
Txh; Read some of the posts on this site about filling the coolant system. ---- p-0128 could be a bad thermostat, low coolant, etc.
Trouble Codes Help txh976 Tech & Performance Forum 12 25 Feb 2014 02:55 am
PO700,PO720 Trouble codes Flowrider Tech & Performance Forum 0 27 Jan 2014 09:21 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
Help with trouble codes? darren70 General PT Cruiser Discussions 1 29 Jul 2011 09:45 pm
Whats the difference between key trouble codes vs odometer ones? sknight88 Tech & Performance Forum 10 22 Jun 2008 04:56 pm
