Another Vibration Question
  • 1 Post By soyomb
Old 27 Feb 2014, 01:46 am
Default Another Vibration Question
Today I took my 08 Vert for a spin after it sat for a month. I noticed the tire light was on so I topped off all tires with 34lbs. After about 6 miles, I heard a thumping vibration almost like a flat. Pulled off and tires seemed fine. Started down the road and around 20 mph the vibration occurred again, got worse and was afraid to go over 40 as the steering column was shaking. No real sound, just a pretty significant vibration. I'm thinking its coincidence it happened after the air fill up. This is my first cruiser & I'm not real mechanically inclined, just hoping for an opinion or two before I take in to a mechanic. No vibration at idle. It's a non turbo with a bit less than 10,000 miles. Thanks in advance!
Old 27 Feb 2014, 02:07 am
Default Re: Another Vibration Question
I'm thinking a belt in the tire came loose. try switching the fronts with the rears and see if that makes a difference.
also, if you jack it up, you should be able to see when you manually spin the tires the difference in the kaput one.
2016 Kia Soul Plus Black
Old 27 Feb 2014, 02:16 am
I'll check that out. Tire tread is "new" but I'm sure they're the originals. That would be an easy fix!
Old 27 Feb 2014, 04:53 am
I bought 4 new tires on-line (Tire Buyers.com) for my wife's car (the old Ford Focus). Took it to my local tire dealer to put on the car. His prices plus what I saved on-line was still cheaper than buying straight from the dealer. Anyway, Brand new tires (NEXEN) and two of them were Out-Of-Round. Couldn't see it unless you looked for it (they should have seen it when balancing them) but they didn't but the car shook all over no matter where we put the tires. Finally they inspected them really well and you could see they were bad while spinning on the balancing machine. Dealer and I weren't happy as he had waste his time after I called Tire Buyers and filed out their on-line forums for them to pick up the tires (so they could inspect) then and then wait till new tires arrived. Believe it or not, one of the replacement tires was bad Had to go through it all again.
Never had a problem with tires from Tire Rack or Discount tires.
Old 27 Feb 2014, 03:31 pm
Just put it on the rack at a tire shop & the tires are fine. When driving it in, the car ran smooth with nary a vibration. Attendant said it could have been the right brake sensor(?) that didn't release properly. There did seem to be a little more wear on the right than on the left. He termed it a "glitch" which wasn't the explanation I was hoping for. But then, it didn't cost me anything, either.
Old 27 Feb 2014, 03:43 pm
Cold where you are?
If your cruiser sat for a month, could've been a "flat spot" from sitting. Used to be more prevalent on old bias-ply tires, but it's still there and goes away when tires warm up.
Old 27 Feb 2014, 10:07 pm
Yes, it's cold, supposed to be -6 tonight. I thought of a flat spot, but the vibration occurred after it was driven about ten miles. I'm not comfortable chalking it up to a "glitch" as the tire guy put it......but it does seem fine now. Guess I'll drive it locally for awhile and see if it reoccurres.
Ok, this is my last question on vibration, I promise. Gru General PT Cruiser Discussions 2 07 Jul 2013 02:39 pm
grinding, vibration question Martybucs General PT Cruiser Discussions 7 09 Nov 2012 06:15 pm
vibration ? 2004PTCruiser Tech & Performance Forum 16 05 Jul 2008 09:40 am
Question on Muffler Vibration ???? Cruiser_108 General PT Cruiser Discussions 8 27 Feb 2008 03:39 am
Vibration between 40 & 60 mph???? anyone had this? gtbright General Turbo Discussions 10 16 Jul 2005 03:06 pm
