Rough Idle In Drive But Smooths Out In Neutral - ????
Old 27 Feb 2014, 08:02 am
Default Rough Idle In Drive But Smooths Out In Neutral - ????
I have a 2002 DreamCrusier. All stock.
I was getting a roaring kinda growling sound at idle in gear. It was a lil rough as well. I would put it in neutral or park and it smooths out. I checked the forum for clues and then I replaced the spark plugs and wires. The problem went away for a couple days but now its back.
Any ideas? If the plugs and wires took care of it, why would it be a problem so soon again? Bad parts? Something else causing the plugs or wires to go bad? Something else all together?
Any help would be appreciated.
Old 27 Feb 2014, 08:44 am
Default Re: Rough Idle In Drive But Smooths Out In Neutral - ????
Was there oil in the spark plug wells?
Old 27 Feb 2014, 10:35 am
No, not that I could see.
Ive had the timing belt replaced and then the tensioner broke and I had to have it done again and get the head redone. It ran fine after that and I havent noticed any loss of oil.
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
Engine Whine On Accel/Decel In Neutral Or Drive bpancake Tech & Performance Forum 2 13 Jan 2014 05:05 pm
'07 PT - Rough Idle, rough acceleration, and shuts off if it idles for too long La_Bruja Tech & Performance Forum 3 09 Aug 2013 07:50 am
Rough Idle 32seventeen Tech & Performance Forum 4 15 Jan 2013 10:10 am
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
