2008 PT CRUISER CONV
Old 01 Mar 2014, 01:26 pm
Default 2008 PT CRUISER CONV
HELP - ABS/BRAKE SENSOR LIGHT COMES ON-GOES OFF-COMES ON.
BRAND NEW BRAKES 2013. HOW CAN I GET THE LIGHT TO SHUT OFF
PERMANENTLY ???
PLEASE
AND
THANK YOU,
CHRIS
Old 01 Mar 2014, 01:50 pm
Default Re: 2008 PT CRUISER CONV
Chris, welcome to the forum.
Did the ABS light start acting up right after you put your new brakes on or has it been awhile since they were installed?
Old 01 Mar 2014, 03:12 pm
Ray_Dockrey's Avatar
Is the brake reservoir full?
Old 01 Mar 2014, 11:13 pm
PERMANENTLY ???
PLEASE
AND
THANK YOU,
CHRIS
ABS sensor is attached to the wheel hub and has a wire running from it. When the brake service was done, did they ck this harness and sensor? Sometimes they get rusted from salt and just normal corrision. There is a magnetic pickip on this part with the wire that reads the teeth on the inside of the wheel. The computer calculates the on /off from the magnetic pull and if there is an issue with the sensor lining up properly then this can happen(the light).
The place that did the work may have pushed on or all of the sensors out depending on if you had al 4 wheels done or just 2. Take it back to where the work was done and have them recheck it.
2005 PT Cruiser Conv. jasonbgriffin PT Cruiser Convertible Forum 3 16 Aug 2010 09:26 pm
Yellow??? PT Cruiser GT Conv. wayneman PT Cruiser Convertible Forum 13 10 Aug 2010 01:58 am
auxiliary audio input jack new 2008 conv. naugie Sound and Security Forum 4 12 May 2008 02:26 pm
Base Conv. VS Touring Conv. matt87951 PT Cruiser Convertible Forum 13 22 May 2007 12:22 am
New '05 PT Cruiser GT Conv. rebel97 PT Cruiser Convertible Forum 0 04 Jun 2004 06:21 pm
