Air from the Dipstick tube!?!?
Like Tree2Likes
Old 03 Mar 2014, 12:48 pm
Tucker05's Avatar
Default Air from the Dipstick tube!?!?
So this weekend i started my PT let it warm up. Made it like 1/4 mile away and there was an ungodly loud whine, like a belt, or a loose pullie some where. Drove it back home and parked it. no codes nothing. Looked at it yesterday and nothing, then it warmed up and screaming began. I wanted to check the oil for foam and it went poof air came out and the whining stopped !!! put the dipstick in and whin whin whin pull the dipstick and air lets out and no whining !!! idk but the dipstick pressure release must be shot. lol
Old 03 Mar 2014, 01:58 pm
Default Re: Air from the Dipstick tube!?!?
Check your PCV valve and hoses and the breather hose and filter at your air box. While you are there clean it! If the air pressure continues then seek someone that can do a compression test and is necessary a cylinder leak down test. Nothing to get worried about at this time!
Not sure what the model PT you have but if you have an aluminum valve cover with Turbo engine and twist in PCV valve on the top passenger side of the engine I recommend getting an AIRTEX PCV valve. They proved through random pressure testing better then all other including OEM.
Old 03 Mar 2014, 02:22 pm
Tucker05's Avatar
I have a 2005 pt gt turbo.
Old 03 Mar 2014, 02:24 pm
auh I see... good deal. Then everything as I recommended!
Old 03 Mar 2014, 02:27 pm
Tucker05's Avatar
OK cool !! if it warms up i will try it
Old 03 Mar 2014, 02:38 pm
no serious response from me... but on a funny note
they commonly pop OUT on DSM's making high boost, so someone came up with this "fix":
STM: SPRUNG OIL DIPSTICK | 90-99 DSM
Old 03 Mar 2014, 02:46 pm
Tucker05's Avatar
LOL nice
Old 03 Mar 2014, 04:38 pm
$100 for a dipstick with a "bung"
I'm not quire sure what I just saw but that seems a tad pricey, I can get new headers for that yo :-p
Old 03 Mar 2014, 05:56 pm
boonie2's Avatar
LOL spring loaded dipstick
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 04 Mar 2014, 07:37 pm
Tucker05's Avatar
This weather is not good for auto repair! And have to check the pcv valve and hose. I was thinking i have about 130k and i think i should just do the head gasket timing belt and timing componets and water pump. And then check the pcv valve and tube just so i have all the issues covered.
Have You Checked You Oil Dipstick Tube Lately? Jetta02awp General PT Cruiser Discussions 15 06 Mar 2011 03:48 am
Engine Oil dipstick handle broke off in tube Samson General PT Cruiser Discussions 8 13 Nov 2010 09:39 pm
Black oil on dipstick R_I_PT Turbo Performance 3 30 Dec 2008 06:25 pm
Broken dipstick tube white Tech & Performance Forum 2 30 Nov 2008 03:19 pm
