Hi,
so first of all, I have to say I am impressed by the forum. I had some issues with my PT Cruiser (2002, touring, automatic) and usually this forum had all the information that I needed. That was pretty impressive and really helpful! I now searched a bit, but did not find a specific answer for my current problem (why is there always something wrong with the car?....): A couple of weeks a ago I changed the TCM module (had the errorcode p0605). Check engine light went away and no error codes are present in the car. However, sometimes now the shift into the first gear is rough and the car does shake a little. It does not happen all the time and I could not find a pattern. This started right after I changed the TCM. Right after there were a couple of more violent shifts and I think they were bit more frequent. Prior to that I never had issues with shifting gears. As I bought the TCM from carcomputerexchange, I asked them, and they said that I should change the solenoid pack for the transmission. I am now a little bit skeptical as this really could be the issue. In particular given that it shifted fine before the TCM went bad. Any opinions? Would this be a logical step to do or is it more likely that the TCM is not working 100% properly? Any advice/thoughts would be really great! Thanks, Thomas |
Yes yes, not wanna go into detail of my late PTC issues...
![]() Well, the reason I am not trusting the "experts" so much in that case (well don't trust them in general, but that is another issue ![]() On a related note - I am going for a trip on the weekend, will be ~600 miles, I guess I still could risk it driving? I got stuck once now with a broken car, not really keen to redo that.... Thanks, for the welcome, you are the best ![]() |
You assumed when I said "expert" I was referring to the shop you purchased you TCM from!
![]() ![]() IMO I would at least change your fluid and filter before adding to many more miles on a questionable mechanical condition.. It is easy enough to do and semi inexpensive. You may also want to get a bottle of fluid conditioner as well? |
hehe, well that was the only one that might have been close to something like an expert, hence....
![]() Currently, I am not sure if my Cruiser will ever make it out of the state of 'questionable mechanical condition'.... How much would that change roughly be? |
A "flush" of your transmission with a filter change by a place with a flushing machine runs about $200 - be sure that all that is used is ATF + 4.
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles |
Some people should continue to learn about new things and not settle for what they once knew as absolute!
![]() PLEASE NOTE! This module is PLUG-and-PLAY. No Need To Visit the Dealer! Comes With 1 Year Warranty! 2002 02 Chrysler PT Cruiser ECU ECM PCM engine computer engine control module brain box Many ecu, tcm, pcm, etc., from re-builders have the ability to load the appropriate information into the units so the need to go to a dealer and spend more money not necessary. Quote:
^^Don this is good info and generally I would also recommend it but in this case I sense the need for inexpensive and something that easily and affordable be accomplished now? ![]() To be taken into consideration it is not necessary get a transmission flushed unless you have discolored fluid or during the filter change find unusual amounts of copper or aluminum in the pan. A simple 45 minute DIY driveway transmission service will generally do the trick. ![]() |
![]() Quote:
I checked the tranny fluid and this seems pretty clean, no dirt and fully transparent.... So transmission fluid change and I'll also order the solenoids, seems also a thing you can do yourself. |
![]() Quote:
IF you followed the instructions then you should be fine. Jerry Last edited by wwpptc; 05 Mar 2014 at 11:09 pm. |
Tags |
solenoid, tcm, transmission |
Thread Tools | |
Display Modes | |
? about Trans Solenoid Pack | dougk | General PT Cruiser Discussions | 2 | 29 Dec 2011 02:00 pm |
Transmission Solenoid Pack??? | mdfrodolives | General PT Cruiser Discussions | 4 | 17 May 2010 08:13 pm |
'06 PT: Solenoid pack? | Kell | Tech & Performance Forum | 3 | 08 Sep 2009 12:55 pm |
Solenoid pack replaced, still a no go... | sknight88 | Tech & Performance Forum | 3 | 19 Dec 2008 07:29 pm |
41TE Trans. Solenoid Pack, I have 2 part #s??? | sknight88 | Tech & Performance Forum | 10 | 16 Nov 2008 04:49 pm |
