A while back I had a leak in my rear wheel brake cylinder. Got that fixed and now, when I brake, I get a clicking noise from that wheel. I checked the auto adjuster, and it looks ok, could the brake fluid have bled into the bearing and caused a bearing failure? or any other suggests as to the clicking noise?
tnx. |
I had a similar issue with my 03. I had a clucking/clicking sound every time I used the brakes. Drove me nuts. Check all the rear suspension could not find anything. What I finally found was the inner brake pad had came loose from the attach spring mounting clip. The inner brake pad was rattling around against the metal hardware.
Original join date: SEP 2003 Steve/ Wayne NJ 2005 GT Vert / Black / 5 speed 2004 Dream Cruiser / 5 speed Traded for 12 Veloster 2003 GT / Blue / Auto /sold 2001 Touring/ Silver / 5 speed /sold on E Bay |
If the shoes got saturated with fluid. They can stick to the drum making that sound. Or recheck the hard ware to make sure everything is as it should be . Fluid can't get to the bearing.
![]() Quote:
1) He says it only clicks when hit hits the brakes, with the pad problem, the clicking would go away when I hit the brakes... 2) He mentions an auto adjuster, which implies rear drums...
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles |
Thanks all for your replies.
I am going to jack her up tomorrow and see what the stickiness sit. looks like. When I spin the drum, (it's an 01) there is no clicking noise, so I am led to believe that it is something that will only make that noise under pressure. The braking doesn't seem effected, however with ceramics in the front, and the back brakes only really working hard when there was a load, it's hard to tell about the quality of the back brakes. When I have it open, I'll take some pics, worth a thousand words. |
Thread Tools | |
Display Modes | |
Wheel Bearing's anyone? | TrannyManny | Wheels, Tires, Suspension | 13 | 30 Oct 2011 10:14 am |
Wheel bearing!!?? | jrs61282 | Wheels, Tires, Suspension | 0 | 11 Jun 2011 12:46 pm |
Rear Wheel Bearing/Hub Assembly Question | FleshEater | Tech & Performance Forum | 0 | 19 May 2011 02:09 pm |
Rear wheel bearing???? | bluewagon | Wheels, Tires, Suspension | 1 | 06 Jun 2010 06:43 am |
which wheel bearing | musicmanchuck4 | Wheels, Tires, Suspension | 0 | 08 Apr 2009 06:48 pm |
