So It sounds like I have a vacuum leak, This sucks.
Like Tree6Likes
Old 11 Mar 2014, 06:56 pm
Default So It sounds like I have a vacuum leak, This sucks.
I apologize for the pun.... It was intended. The previous owner changed the spark plugs himself on my 01 2.4L limited m/t n/a. It sounds like there is a vacuum leak coming from this line that is coming off of the manifold, The one which is removed when the plugs are changed. It might not even be a vacuum line, That's why I included this horrible picture for you..... The top is drivers side.
It seems like the flange is uneven when I look at it from the passengers side. Is there some sort of seal in there that might have been damaged during the plug job?
1998 Mazda 626 - looking for a new home
'01 PT cruiser limited Inferno Red- Mopar sub (Finally) stock chrome rims LED map/ dome/ trunk lights LED Footwell lights
Planned upgrades- Heated seats, 18-19" rims, chrome grille, drilled/ slotted rotors, clean up the calipers/ paint the wheel wells, 3" cat back exhaust, new spark plug wires, Speakers all around, Either new head unit or an AUX integration.
Old 11 Mar 2014, 07:31 pm
Default Re: So It sounds like I have a vacuum leak, This sucks.
Yes, there is an o-ring that seals the EGR tube to the intake. Yours is probably damaged or missing. Either way, you need to replace the o-ring.
Jerry
RedLimited likes this.
Old 11 Mar 2014, 07:41 pm
Thank you very much. Now I know what I am doing in my 15 minutes of free time this weekend.
Old 11 Mar 2014, 08:51 pm
Here's mine, I just took a picture and it doesn't leak.
Looks almost like yours except my washer is blue. Try tightening the two different sized bolts on each side down tighter. I believe one is 8 or 10mm and the other is 13mm.
Old 11 Mar 2014, 09:27 pm
Thanks Crewzin!!!! I might pony up the whole $5 for a new gasket. Now that I look closely at the picture it looks like there is a split in the seal.....
I forgot to put the vanity cover back on so I ran outside to take two more pictures... looks split to me. Thank you all for the help... I'm new to the Cruiser and despite what my friends think about cruisers I'm in it or the long haul.
wwpptc likes this.
Old 11 Mar 2014, 09:50 pm
Check out the 11th or 12th pic in this thread. It shows the complete gasket.
Spark Plug Guide
Jerry
Old 11 Mar 2014, 10:01 pm
Yep!!! thanks!!! I'm getting a new one. My last post I added two photos.
Old 11 Mar 2014, 10:08 pm
Yep, the second pic clearly shows a cracked gasket.
[IMG][/IMG]
Jerry
Old 11 Mar 2014, 10:21 pm
So would I be right in thinking that this would reduce engine performance? Its loud enough to hear when the car is running (Windows down). As soon a I touch the gas pedal it makes a sucking/whining noise.
Old 11 Mar 2014, 10:41 pm
Good luck with your new gasket.
I just stopped in to say I traded my 1998 Mazda 626 for my 2002 inferno red PT.
Uncanny.
2016 Kia Soul Plus Black
vacuum leak clsals Tech & Performance Forum 11 21 Apr 2015 09:21 pm
vacuum sucks.. chevelle_ss_396 Tech & Performance Forum 24 09 Mar 2014 09:45 pm
Possibly a vacuum leak? sleepy General Turbo Discussions 6 10 Jul 2012 09:58 am
Vacuum leak? Mulligandog Tech & Performance Forum 6 25 Feb 2011 09:00 am
Vacuum leak help discovering06 Tech & Performance Forum 11 14 Jan 2011 03:33 pm
