Cruiser makes a grinding noise when idling?
Old 13 Mar 2014, 06:04 pm
Default Cruiser makes a grinding noise when idling?
I hope you guys can help me diagnose this issue, it seems to me like it's something with the transmission. What happens is that occasionally when driving, I hear a grinding noise coming right from near the pedals, near the engine block. I've sized down the problem to occuring when:
  • I am starting the car from being cold
  • I back up, with-out giving it any gas
  • When it's in park
  • When cruising, but only occasionally. I haven't been able to pin point what speed influences that yet
Pretty much, when I'm not giving it gas, it starts grinding. It almost sounds like something is slipping, but this sort of thing is pretty beyond me. Also it seems like the grinding isn't AS bad once the engine is heated up. Extra info you might want to know,
  • It's a 2003 model,"Touring Edition" Not turbo (I hear some of them are, apparently?)
  • Recently I had some work done where the thermostat was changed out, and some radiator coolant spill onto the engine block, near the radiator cap
  • This grinding noise came up 2 days after the thermostat repairs
  • No check engine light, engine temperature is normal, everything else is normal.
I hope you guys can help me figure this out. I'll be honest if it's a serious issue I'll be taking it to a garage to get any real work done, but I'm hoping you can help me diagnose it anyways. At the very least, I'll be able to brace myself for what I'm dealing with.
Old 13 Mar 2014, 06:09 pm
randyincctx's Avatar
Lightbulb Re: Cruiser makes a grinding noise when idling?
Have you checked to make sure the mechanic that worked on it didn't drop a tool or something in it?(it happens!)
Aka:~KILLER~
Old 13 Mar 2014, 06:21 pm
Default Re: Cruiser makes a grinding noise when idling?
There's no real moving parts that i can think of anywhere around where he would need access to the thermostat. But as Randy said, if he happen to lay a tool or part on another part of the engine and it slipped down, who knows what might happen. He also might have got under the car to release the radiator plug to drop some coolant for access of the thermostat. Are you able to get under the car to see if you might have picked something up while driving? A stuck branch or something might be leaning on a moving part that you wouldn't hear unless you were at low speeds.
Grinding noise coming from my 2005 PT Cruiser PTClueless Tech & Performance Forum 9 03 Feb 2014 10:46 am
What else makes grinding noise? 808 Wheels, Tires, Suspension 14 04 Apr 2012 04:21 am
My Car Makes Hissing noise when driving.. no noise from reverse or netural kasasoze Turbo Performance 3 04 Dec 2011 09:07 pm
Grinding noise while slowing down, whirring noise while speeding up thedarkcanuck Tech & Performance Forum 5 27 Nov 2011 10:15 am
A/C noise when idling 2002ptcruiserwoody723 Tech & Performance Forum 3 05 Nov 2009 02:16 pm
