Hi all,
My '06 turbo is having some mystery problems, and the symptoms are quite frankly confusing me and the repair shop where I have it, so I thought I'd ask the experts. -Been having white (maybe white/blue) smoke out of the exhaust when starting up for about a week. Does not smell sweet, like I have heard coolant does. It smells like burning hydrocarbons. -No overheating. -Took car for an oil change Wednesday, and the coolant was very low. They refilled it. It is still fine, not low, so if there's a leak, it's not a fast one. -I (and the mechanic) can smell a sort of burning smell inside the car. -Last night, white smoke was coming out from the hood after I had driven it for about a mile. Has not happened again. -Before the oil change, the oil light blinked on twice. I immediately took it in. -Shop can't find any noticeable external leaks. -Possibly, there is some hesitation, lack of smoothness (if that makes any sense) when I accelerate, particularly a "hard" acceleration from a standstill. -A few times while accelerating, I've heard a repeated clicking noise. Doesn't happen all the time, not sure if it's related. I was suspecting head gasket, but was told it would be overheating if that was the problem? Is that true? I'm about an hour from my home and trying to figure out if it's safe to continue driving. Thanks in advance for any thoughts you might have. You guys are the best. |
Idle is fine, not rough. I finally had the same conclusion about the PCV after reading lots and lots of other threads. Car has 160,000 miles, and I don't think it's ever been changed. Is this something a non-mechanical person can change easily? I see the part is fairly inexpensive and from what I've been reading, it's just a matter of finding the piece and switching it out - don't have to take anything else apart. Is that accurate? What should I know to watch out for?
It's a fairly simple task,especially when you have a group of people helping with the instructions........
The hardest part will probably be removing the old,especially if sealant(RTV) or thread tape was used previously,plus being in there for so many years/miles! ![]() First thing is to locate the PCV valve (see photos),then take/pull off the rubber/plastic hose,and then unscrew the old valve using a 24mm wrench. Installation is basically the reverse;Screw the new valve in,torque to 70 inch lbs(or fairly tight,NOT too tight!),then re-attach the rubber/plastic hose...and your done. ![]() ![]()
![]() Aka:~KILLER~ ![]() |
The pvc valve is on the other side of the valve cover on top for turbo's.
2003 GT- Stage 1, Mopar BOV, 2.75" catback, Hurst SS, Eibach pro-kit, 6000k fogs, Alpine CDA 7893, 10" Alpine Type-X powered with JL Audio e1400d, Alpine Type-R components powered with JL Audio e4300. |
![]() Quote:
And on my '05, doesn't screw in, is a push and 1/4 turn twist.
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles |
If your turbo has a quite a few miles you may want to pull the intake hose off and check the play in the shaft . In and out and side to side.
Anyone have problems getting the part? The parts stores' computers show a straight valve, not the angled one that came out of the car. When I brought the actual part in, they said it has to be ordered from the factory. The dealership here thinks they have one, but I'm less than optimistic at this point.
Thread Tools | |
Display Modes | |
03 pt. turbo alt.problems | Broomstix | Tech & Performance Forum | 4 | 18 Aug 2013 12:47 pm |
Turbo problems...help! | loki547 | General Turbo Discussions | 21 | 06 Aug 2011 11:06 am |
Turbo problems? | PTCruisinTurbo | General Turbo Discussions | 29 | 30 Jan 2011 04:08 pm |
'04 PT Turbo/GT stalling problems! | pcm2a | General PT Cruiser Discussions | 1 | 01 Oct 2007 07:53 am |
Major Turbo problems | Iris | Turbo Performance | 7 | 04 May 2004 07:06 pm |
