P0300/P0335
Old 15 Mar 2014, 05:29 pm
Puddin's Avatar
Send a message via Skype™ to Puddin
Unhappy P0300/P0335
REPLACED : Camshaft sensor @ 68,000 and 72,100
REPLACED : Crankshaft sensor @ 68,000 and 85,800 and (NOW) 89,600
I will be replacing it tomorrow (Sunday) with a NAPA part. And getting a MOPAR for the next time. Or I'll switch it out when I get a couple of hours on the weekend.
What is going on? I was told by a mechanic that my COIL wasnt putting out enough power at the first repair. Could this be the problem? Or ????? This Fresh Cruiser need some help.
Old 15 Mar 2014, 06:44 pm
Default Re: P0300/P0335
Most of us that went right for the MOPAR sensor when the first one failed never had to change it again. There are some that say the MOPAR sensor is just like all the other sensor in every other store but we've proved that the MOPAR one seems to last a lot longer for some reason.
If you trust the mechanic and he said the coil isn't putting out enough spark, it's easy enough to put a new coil in and chalk that off the list.
Old 15 Mar 2014, 06:56 pm
randyincctx's Avatar
Post Re: P0300/P0335
With the money you spent on those 5 sensors,it would have been worth it to go Mopar the first time.
Also,it might not be a bad idea to check both wiring harnesses for any wear & tear;If the CPS wires get in-between the radiator hoses,it can cause thermal breakdown of the insulation,and the CKS wiring has been know to come into contact with the axle,which wears thru the insulation(CREWZIN knows this too well).....Both of those situations can result in a ground fault,and can/will trigger CEL codes.
Aka:~KILLER~
Code P0300 won't crank ckomck General Turbo Discussions 0 12 Dec 2013 07:12 pm
Codes P0300 and P0203? unioncreek Tech & Performance Forum 4 09 Mar 2013 03:19 pm
my pt has error codes p0335, p0339,p0116...help please jrbsr05pt Tech & Performance Forum 2 06 Mar 2012 11:45 pm
Error Code P0335 firemedic1560 Turbo Performance 14 15 Jan 2012 12:42 pm
Code P0300 rszappa1 Tech & Performance Forum 2 30 Nov 2005 12:47 pm
