New guy with problems--Cylinder 3 Misfire
Old 15 Mar 2014, 11:26 pm
Post New guy with problems--Cylinder 3 Misfire
Hello everyone I, am new to the forum and need some help.
I own a 2007 Chrysler PT Cruiser that had a cylinder 3 misfire. My first mistake was I, replaced the coil,wires,spark plugs thinking this was my problem. Put everything back together and fired it up......same problem.
Went to our local Harbor Freight and purchased a engine compression tester and found that the #3 cylinder was 0. Pulled the head and found a burnt exhaust valve on #3-- off to the machine shop and $545 later(new timing belt kit,water pump,head resurfaced,new valve). Put everything back together and it still has a miss at idle even if you were to increase the rpms it still sputters. It now has more power no check engine light but I can't seem to loose that miss?
Thanks in advance for your help.
Cylinder 3 misfire michalo187 Tech & Performance Forum 12 28 Jan 2017 09:30 pm
Code cylinder 2 Misfire help Kris35 Tech & Performance Forum 6 24 Mar 2012 09:01 pm
Misfire In Cylinder 4 shoe989 Tech & Performance Forum 13 23 Feb 2011 03:56 pm
cylinder 2 misfire problem flexse1 Tech & Performance Forum 1 07 Oct 2009 05:58 am
Cylinder Misfire TaylorMade Tech & Performance Forum 6 16 Jun 2005 05:01 pm
