I have an 06 PT cruiser touring non-turbo manual tranny. When I put the car in gear and push the gas, it doesn't move, all that happens is the engine revvs up. I have tried it in first and reverse. just prior to this happening, I was on my way home and all was well. Then I made a stop and proceeded to go but the car barely moved & it just revved the engine to 3rpm when I pushed the gas. I was finally able to make it home, although I only had a mile to go. That is when I tried again. It starts just fine but I noticed it shifts into gears more easily than it did before. Any ideas? I obviously cant drive the vehicle to a shop for them to look at.
Thank you very much |
Sounds like the clutch was burnt to smithereens
Useful Documents Useful How-To's Have an engine code? Sometimes this link is helpful Neon Bobble Strut ^^ Click |
Mileage on car, mileage on clutch?
1999 Dodge Neon Coupe. DOHC 5 speed 2005 Crossfire SRT-6 2005 PT Cruiser GT 5 speed. 1 of 21 (SOLD) |
The car has 77,000 miles on it & nothing major has been replaced. So the clutch would have the same.
I was reading in the repair manual to check the clutch fluid reservoir & that it is located on the firewall next to the master cylinder, but there is no reservoir that I see at all except the brake fluid one that is supposed to be in the same place pretty much. The clutch pedal isn't mushy or real loose either. It feels the same as it always has. The gear shifter moves into each gear with no problems and there is no grinding or any other noises when shifting gears or pushing the clutch pedal. I don't understand why, when the clutch & gas are both released and the car is in gear, the car doesn't die. This all happened the same day. There was nothing at all that lead up to these events that has been wrong with the vehicle. I really appreciate any and all help I get...Thank you very much! |
No there wasn't any smell when it happened or now. The car was primarily my moms until about a yr ago. We both have driven cars professionally for a living and know how to drive a stick. I did find out that the clutch is engaging though.
Very strange symptoms. You say you haven't beat on it and that it happened all of a sudden. It might not be the clutch then. Maybe something to do with the output shaft of the tranny? Or somewhere in the drive train? Idk I'm stumped
2006 PTGT with 5spd. ~60k miles |
Maybe the disc failed, basically the hub on the disc might be seperated from the rest of the disc.
Let us know what you find.
![]() 86 TurboZ CS 2.2 T2 +20's A555 00 Durango SLT+ 5.9 4x4 02 Grand Cherokee 4.7 4x4 03 PT GT Black 5 sp Stg 1 sold 05 PT GT Silver 5 Spd Conv 06 PT GT Cool Vanilla 5 spd Conv 06 PT Base Marine Blue 40TE Conv 15 Grand Cherokee Overland 5.7 QD2 17 Challenger SRT A8 GoMango 18 JL Wrangler Sahara Punkn 20 JL Wrangler Rubicon Ocean Blue |
I had it happen on a '69 Volvo - I destroyed the spider gear in rear differential - I had same symptoms - except -
"Then I made a stop and proceeded to go but the car barely moved & it just revved the engine to 3rpm when I pushed the gas. I was finally able to make it home, although I only had a mile to go." When a gear is destroyed, you get NADA, no creep - some creeping sounds like clutch, but that quickly??? You will HAVE to let us know what it is.
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles |
Thread Tools | |
Display Modes | |
03 PT Tranny Problem | Blazinator | Tech & Performance Forum | 23 | 10 Mar 2014 01:14 am |
replaced clutch & used 5spd tranny now no start | 96realwe | Tech & Performance Forum | 9 | 09 Sep 2013 06:30 pm |
New member with a tranny problem- help! | hudsonhornet7x | Tech & Performance Forum | 8 | 27 Jun 2012 09:39 am |
Baffling Tranny Problem | 07PCH | Tech & Performance Forum | 7 | 02 Aug 2011 04:52 pm |
Clutch, Tranny or something else??? PLEASE HELP! | thejenius77 | Tech & Performance Forum | 17 | 15 Apr 2011 02:52 pm |
