2001 Limited Intake Manifold warped ???
Old 19 Mar 2014, 09:07 pm
Default 2001 Limited Intake Manifold warped ???
I have a 2001 PT Limited with 55k miles....started running rough.......#4 cylinder misfire......replaced plugs, wires, Intake gaskets (o-rings)........cannot get upper/lower intake to seal......can heat and feel #4 leaking....
Is this caused by warpage ??
Is it best to replace top and bottom or just the top ??
Is this a somewhat common problem ???
WHERE can I buy a new intake ??
I found one at chrslerpartsdirect for 115 bux, but it does not say if it is the top...bottom...or both ??!!!!!!!
Thanks for any help...
Old 19 Mar 2014, 09:13 pm
Default Re: 2001 Limited Intake Manifold warped ???
Very unlikely you need a manifold, most likely it's gaskets.
Old 19 Mar 2014, 09:25 pm
That has been my thought also....but we have tried new gaskets from oŕiellys....new gaskets from the dealer......added silicone to the area.....and #4 just will not seal......it's really aggravating....
Any other thoughts/suggestions ?
Old 19 Mar 2014, 11:00 pm
Sorry, re-reading, you did say you replaced the gaskets.
Any signs on the gaskets you took out? Pinching/discoloration?
Torqued in proper sequence and to right torque?
Haven't heard of warped intake - not saying it's impossible, but...
WTB....intake manifold to fit 01 PTC boxersix Classifieds: Want To Buy 1 19 Jul 2011 12:05 pm
wtb 05-up upper intake manifold, throttle body, intake hose to turbo,aircleanor lid 1autodr Classifieds: Want To Buy 1 24 Feb 2011 05:15 pm
intake manifold??? PTcruzer02 Turbo Performance 5 26 Dec 2008 10:58 pm
Gas in intake manifold bigdangerous24 Tech & Performance Forum 9 16 Mar 2008 08:32 pm
GT Intake Manifold TaylorMade Tech & Performance Forum 13 01 Dec 2004 11:23 am
