2006 PT maxes rpm at 3500 and dies at idle speed
Like Tree4Likes
Old 21 Mar 2014, 09:54 pm
Question 2006 PT maxes rpm at 3500 and dies at idle speed
2006 PT, not turbo, touring edition
running like crud. maxes out rpm at 3500 and acts like limiter has kicked in. won't idle, just dies unless holding foot on the gas. also hard to start, have to hold foot on gas at just the right amount to get it to start. got the codes pulled, they are listed below. things i have already done include new fuel pump, new catalytic converter, new muffler, new crank shaft sensor, (new cam shaft sensor goes on saturday, its sitting on the shelf right now waiting for me to have the free time and daylight), new idle air control valve, new throttle position sensor. unrelated but just to add, also a new waterpump and timing belt. (problem was there before new water pump and timing belt were installed, and got no worse) after each new thing was installed, the car would run normal for about 5 seconds, i assume while the computer was sensing it or whatever. i can't figure that part out. after the 5 seconds of the car being like "oh hey, whats this new gadget... kinda cool... oh nevermind ima run like a POS again, sorry bud," it just goes back to dying unless foot on gas.
so here's the codes that got pulled about two months ago (well, one is an actual "code" the others are spelled out):
p2074
mass air flow sensor
random misfire cylinder 3
idle control circuit low
iat sensor
o2 sensor high voltage
map baro sensor
throttle pedal position sensor
Any help is certainly appreciated. Thanks
J
Old 21 Mar 2014, 11:02 pm
randyincctx's Avatar
Lightbulb Re: 2006 PT maxes rpm at 3500 and dies at idle speed
Originally Posted by bundixlake View Post
p2074
iat sensor
map baro sensor
With all of that going on,and all you have done (or checked) already,being a 2006 PT Cruiser,the first year they went to Can-Bus electronics,there could possibly be a problem with your TIPM (not unheard of).
Aka:~KILLER~
Old 22 Mar 2014, 10:46 pm
Default Re: 2006 PT maxes rpm at 3500 and dies at idle speed
i hope not. that thing runs about 800 bucks, doesn't it?
Old 23 Mar 2014, 08:31 am
Ray_Dockrey's Avatar
Have you replaced the map sensor? It can cause issues like you describe.
Old 23 Mar 2014, 10:44 am
Try switching the plugs on the IAC and TPS. Some people plug them in wrong. Same shape connector, easy mistake to make any time they get disconnected for other maintenance, such as removing the upper intake to change the spark plugs or fixing a leaky valve cover gasket
Old 25 Mar 2014, 03:54 pm
@rob342: i just went out to try that, and the IAC plug won't even reach (by about three inches or so) to the TPS and so that isn't the problem... but good idea anyway.
Old 25 Mar 2014, 05:45 pm
on my way down for a new map sensor now
Old 25 Mar 2014, 08:38 pm
well put on new map sensor but cant tell if it works because now it wont start at all. fuel not getting to engine again... acting like it did when my hose slipped off my new fuel pump. except now it has a full tank of gas, so dropping the tank again will be a bitch. i clamped the crap out of that hose, too. i hate this car.
Old 25 Mar 2014, 11:49 pm
2step's Avatar
If you are trying to rev the RPM above 3500 with the car sitting in neutral then, yes, there is a limiter to prevent "over reving" the engine when not in gear. Normal. The idle problems can be a number of things including plugged or stuck injector(s). You might try pulling the spark plugs right after shut down to visually check to see if they are all equally wet/dry. What you're describing doesn't sound like a vacuum leak exactly but don't rule it out. Those are a couple of ideas you can try that don't cost anything to check. But they are minor projects. So far you have been throwing new parts at it hoping something will work. You are going to pretty close to what it would have cost you to have a mechanic fix the problem. In any case, I hope you get it all sorted out soon.
bundixlake likes this.
Old 26 Mar 2014, 04:51 pm
well thanks for letting me know that about the RPM. be hard to pull the plugs right after shutting it down, since you gotta take off all that crap from the top just to get to them. they looked pretty good when i changed them though. the mechanic i asked about it a while ago told me he'd be doing the same thing as me, just changing all the sensors until something worked, since that's what the code reader was saying was wrong. he said it was "hit and miss" because with a problem like this, you can't really know what's going on for sure. i've got to drop the tank this weekend to see if that hose slipped off of the fuel pump. i dont know how in the hell it could have, i clamped the crap out of it, but who knows with this car. thanks.
-Very- Rough Idle and engine dies + hot air purplecruiser Tech & Performance Forum 6 27 Feb 2015 11:09 am
Very Rough Idle, engine dies sometimes jonlouisville77 Tech & Performance Forum 13 03 May 2012 12:37 pm
Rough idle - dies. bigtop1228 Tech & Performance Forum 13 29 Dec 2011 10:19 am
rough idle and dies bompa45 Tech & Performance Forum 19 29 Mar 2009 09:19 am
