hi, i just bought an 04' pt cruiser and it was over heating, i replaced the thermostat and the radiator and it helped allot ! unfortunatly it still over heats after around 30 to 40 minutes of straight driving,
i also had them run the test for carbon monoxide in the radiaitor fumes and there was zero, also there is no vapor in the exhaust, so i hope that rules out head gasket i ran the codes for the engine light and replaced the relay for the fan, it seems maybe someone jimmied the fan to stay on all the time cause it goes on in the accesory position when i turn the key,, so whats next ?? i heard about a preasure test for the radiator maybe theres a leak in a hose ,??? what about air blockage ? is there anything that i can do ? is there a blockage somewhere that i dont know about ?? what about the water pump ? is it possible that the water pump is half working ?? please help i am at my wits end !! tyvm , ptloser |
when i bleed it is the car on ? is it off ? is it cold ? can you tell me more details i did not bleed it, i also bought a new radiator cap , i had the radiator installed by a mechanic, i doubt he bleed it ???
ok i blead it ! ,, and i did my own test for a faulty water pump and i think i am correct, please tell me if i am wrong,,
i took off the radiator cap and started the car,, i put my hand on the radiator cap hole and there was next to zero pressure to hold my palm,,, also i waited until it got hot enough to activate the thermostat and still zero suction on my palm,, there is next to zero suction or movement in the opening ,, i am next to positive that the water pump is failing because it overheats after 30 to 40 minutes of driving like clock work,, just enough time to bring the water to a boil where it shoots out of the overflow reservoir and causes the over heating. i replaced the radiator , the cap is brand new, the thermostat is brand new, there are zero emissions (carbon monoxide) in the rad water and zero white smoke out the tail pipe, please please please,, tell me that it is the water pump ? lol.... im freaking out |
At this point I think it's either the pump or a leak. You have coolant in the system, right? If you said so, then I missed it, for which I apologize.
I just had to put more coolant in my cruiser. Until we can save up enough to have the heater core replaced, we have to deal with it sloooooowly venting vaporized coolant into the cabin when the heat is on- mainly with defrosting. Mom was on the way home from the mechanic yesterday, with a diagnosis of failure on the driver side front wheel bearing, and it overheated. Thankfully, that was about 5 months after having the radiator replaced and new coolant put in. We'll have to deal with the smell of coolant inside for now, since it's not as urgent of a problem as, say, the possibility of the wheel falling off.
Onyx Green PT Cruiser Touring; Totaled @ 174k ![]() |
How many miles on the PT? If near or over 100,000 miles, you're due for timing belt anyway, and water pump gets done at the same time....
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles |
Thread Tools | |
Display Modes | |
Overheating | Luska | Tech & Performance Forum | 3 | 14 Sep 2013 12:11 pm |
Overheating | snowwhitetiger | General PT Cruiser Discussions | 7 | 31 Mar 2012 09:48 pm |
overheating 02 pt | boomin | General PT Cruiser Discussions | 1 | 15 Mar 2012 10:15 pm |
Overheating PT GT | Fuct | General Turbo Discussions | 4 | 04 Aug 2011 04:46 pm |
Still Overheating | Cruz2success | Tech & Performance Forum | 2 | 19 Jul 2011 10:43 pm |
