Need help with codes
Like Tree2Likes
  • 1 Post By NitroPT
  • 1 Post By NitroPT
Old 02 Apr 2014, 09:34 am
Default Need help with codes
i saw the chart of what they mean, but how do i fix, has anyone come across these?
0513
0522
its a 05 gt, thanks guys
tommy
2005 PT CRUISER GT
Semper Fidelis!!!
Old 02 Apr 2014, 10:21 am
Handy_Cruiser's Avatar
Default Re: Need help with codes
If you will go to the search function and then search for P0513, several useful threads will come up. The same is true for P0522. Be sure to use the "P".
P0522 means oil pressure sensor input below the acceptable voltage. The fix is usually to replace the oil sending unit.
P0513 is an invalid SKIM key code. If you have another gray security key, try it to see if it works. The problem could also be an issue with the SKIM module in the steering column. A battery terminal 'reboot' might also straighten it out. If the car still runs okay, try the battery reboot first. Just disconnect the negative terminal on the battery for about ten minutes. While disconnected you might also turn the key on and press the brake pedal several times. And I say ten minutes as a general time for most cars I've worked on. I think I've read on this forum that it takes less than a minute on a PT Cruiser.
Old 02 Apr 2014, 10:59 am
Disconnecting the battery will only sometimes clear the DTC's from being seen on the dash it will not correct and clear the problem in the PCM.
Old 02 Apr 2014, 02:29 pm
cruserdad1976's Avatar
nitro couldnt you use a scanner to clear the codes and see if they come back???
Old 02 Apr 2014, 03:09 pm
wayne2001ptcruiser's Avatar
I believe you can use that method.
Old 02 Apr 2014, 04:07 pm
Yes! Better scan tools will have 3 area's to veiw and make adjustments. DTC, DTC pending and the reediness. You can clear the DTC but not the pending. You can clear the DTC and pending but not the readiness. If you choose to re-set the readiness then you must drive and cycle the system at least 1 once or 50 miles or more to set readiness or the pending and/or DTC will return if it was not corrected. This is why the battery disconnect does nothing except appease you physiologically not seeing it. It is STILL there you just need to know how and where to find it.
767skyking likes this.
Dash codes--not the usual OBD codes--help! chitowncruiser General PT Cruiser Discussions 5 01 Mar 2013 11:56 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
TOO MANY CODES!!! Nonie Tech & Performance Forum 13 20 Mar 2011 12:21 am
No Codes?? BB General PT Cruiser Discussions 2 13 Aug 2005 08:25 pm
