Brake pedal issues!!!
Old 03 Apr 2014, 09:27 am
Default Brake pedal issues!!!
Hiya all!my brake pedal on my 2004 pt is causing me a headache!the brakes work fine but the brake pedal itself can be pressed all the way to the floor!!the brakes work fully when pedal is about half way down but can still press the brake pedal further?hope this makes sense it's hard to explain!!!its a 2.2 crd which I know isn't available in the states but just wondered if anyone could shed any light on this?my husband thinks it could be the master brake cylinder?
Had a lot of problems with my pt but fingers crossed after this fix we should be good for a years happy motoring!!!
Thanks xx
Old 03 Apr 2014, 10:49 am
Handy_Cruiser's Avatar
Default Re: Brake pedal issues!!!
There's several common conditions that cause this.
* Air in the brake lines. This often occurs after work on the brakes has been performed and is extremely common. The usual fix is to bleed the brakes.
* Back drum brake need adjustment. Sometimes the slack adjusters on rear drum brake don't tighten as they should. The front disc brakes will grab but then it takes more pedal to build pressure on the rear brakes. This varies on different cars depending on how the proportioning valve handles it. I'm not sure about the PT. Adjustment can often be done with a flat screwdriver if the adjusting holes are punched out on the rear brakes.
* Leaking brakes. Often seals go bad in the front calipers or back wheel cylinders. Rubber front brake lines can crack and leak too. This can often be detected by observing brake fluid behind the wheels.
* Master cylinder going bad. If no other problem can be found, this is often the issue. And it usually gets worse with time. It's also a common problem.
There's an "art" to bleeding brake lines, adjusting drum brakes and detecting a slightly bad master cylinder. If you haven't done this type of work before , this is one of the few times I recommend going to a good trusted mechanic. Brakes are nothing to play with. Your life could depend on it. It's money worth spending.
Old 03 Apr 2014, 12:13 pm
Thanks for that!ill get my hubby to check what he can and fingers crossed we don't hav to take it to the garage!the PTs aren't too popular with the mechanics near me!!!!
Brake Pedal Travel bob2006 Tech & Performance Forum 15 21 Sep 2013 10:29 pm
RPM won't go down when brake pedal is pushed! IT JUST KEEPS GOING! HELP! dannypnc Tech & Performance Forum 4 22 May 2013 09:02 pm
brake pedal judder dave1972 Wheels, Tires, Suspension 3 04 Jun 2012 04:34 am
brake pedal question Carl48 Tech & Performance Forum 11 22 Mar 2010 07:51 pm
replacement gas pedal and brake pedal?? legion Interior Accessories Forum 7 17 Jun 2004 10:06 am
