Error codes
Old 03 Apr 2014, 12:41 pm
Default Error codes
Have a 02 2.4L with error code P601 which is internal short in pcm.Can clear code and run engine without code reseting. Code reapears on starting vehicle so I think there is fault somewhere other than pcm . Car runs normal other wise. Has anyone come accros this?
Old 03 Apr 2014, 01:05 pm
Default Re: Error codes
What tool and how are you clearing the DTC?
PM member Busted_PT for some information about getting a re-built PCM
Old 03 Apr 2014, 01:14 pm
Using Actron scanner. But have had ck by two others using a snap on all with same results
Old 03 Apr 2014, 01:27 pm
The Snap-on if a newer model has a good engine code read program. In the hands of a Diagnostic Technician it is a valuable tool.
You most likely have a PCM that is going to fail. You could check the PCM connections pins for damage.
Good Luck!
what these error codes really mean? ManMartin General PT Cruiser Discussions 5 18 Jul 2013 03:55 pm
Error Codes Error lilcruiser Tech & Performance Forum 2 10 May 2012 05:34 am
2 error codes at once heshdog Tech & Performance Forum 9 02 Oct 2011 05:07 pm
ERROR CODES Kirby General PT Cruiser Discussions 4 24 Oct 2006 03:15 am
