'03 PT Cruiser Probs
Like Tree5Likes
Old 04 Apr 2014, 04:18 pm
Default '03 PT Cruiser Probs
Once again my PT stopped working, I truly do not understand why I am having all of these problems with my cruiser.
Today when I put key in the ignition and went to turn my car on all of lights came on and the radio came on too, but the engine wouldn't start, it wasn't even attempting to turn on . It can't be the battery because it was just replaced.
Any thoughts? Has anyone else had this happen?
Old 04 Apr 2014, 04:44 pm
Default Re: '03 PT Cruiser Probs
The error codes I am getting is p0325 & p0171
Old 05 Apr 2014, 08:07 pm
One is too lean, other is knock sensor.
Battery may have been replaced, but if you have something draining it...
You have fog lights? Multifunction switch has been known to go bad and turn lights on randomly, which would drain the battery...
Old 05 Apr 2014, 08:13 pm
randyincctx's Avatar
Lightbulb Re: '03 PT Cruiser Probs
I had the same symptoms/issue.....(no codes though!)
Mine turned out to be a 'sticky' starter solenoid plunger....I was able to free it up by tapping on the top of the casing,while a helper turned the key to start it.
Aka:~KILLER~
Old 06 Apr 2014, 10:29 am
QUESTION:
If it is the starter solenoid, isn't there some sort of a tell-tale click that signifies it is the solenoid???
Or am I confused about that again.
Old 07 Apr 2014, 10:09 am
I don't have fog lights and I just replaced the battery this winter. Whats super weird it that when the guy from AAA came they stuck a rod down into my engine and it started right up, said that the started was the issue. This morning when my mechanic looked at it, he said that my car started right up with no problems and no trouble codes. He can't figure out why my car stopped working. Said that its up to me if I want to replace the starter or not, he said that he thinks that it is going bad but is not 100%. I am most likely just going to have him replace it because a starter is inexpressive and my cars old. It's just a mind boggling situation to me!
Old 07 Apr 2014, 10:11 am
Whats super weird is that when the guy from AAA came they stuck a rod down into my engine and it started right up, said that the started was the issue. This morning when my mechanic looked at it, he said that my car started right up with no problems and no trouble codes. He can't figure out why my car stopped working. Said that its up to me if I want to replace the starter or not, he said that he thinks that it is going bad but is not 100%. I am most likely just going to have him replace it because a starter is inexpressive and my cars old. It's just a mind boggling situation to me! Maybe a sticky started was the issue and when pushed it with his rod, he freed it up?
Old 08 Apr 2014, 08:01 am
check the ground wires from the battery to the starter. They're known to crack with age. there's a few posts on here about it
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 08 Apr 2014, 09:35 am
When he put the rod in. Were you turning the key while he did this? Or was the key just on?
Old 08 Apr 2014, 10:01 am
"Whats super weird is that when the guy from AAA came they stuck a rod down into my engine and it started right up"
Did you turn the key at the same time, or it started just with the rod - either he used the rod to tap and free the solenoid, or, more likely, it sounds like he used the rod to make electrical contact and start the starter.
Could be your ignition cylinder...
MBC location and ECU probs PETEY_CRUISER Turbo Performance 10 24 Oct 2015 08:45 pm
what are the most common probs? ranger Tech & Performance Forum 8 15 Aug 2011 01:33 pm
Electrical Probs R_I_PT Tech & Performance Forum 2 04 Jan 2009 08:36 pm
Air conditioner probs. ccinder General PT Cruiser Discussions 2 18 Jun 2008 09:35 pm
MBC Probs PETEY_CRUISER Turbo Performance 5 20 Jun 2003 02:12 am
