random issues i cant figure out
Like Tree4Likes
  • 1 Post By randyincctx
  • 1 Post By 2step
  • 1 Post By CREWZIN
Old 05 Apr 2014, 03:05 pm
Default random issues i cant figure out
i still have an 05, i havent posted here in a long time since the car has been doing fine.
here recently, i can drive down the road and the car acts like it wants to die. ive gotten codes with cam/crank and both have been replaced, pcv is fine, hoses are firmly connected with no leaks, but the problem still occurs.
its very random and unpredictable and for the life of me i cant figure it out. the timing belt and water pump was changed at ~100 and im at 118 now. it doesnt slip and accelerate as if its the transmission, its just the engine randomly losing power and returning to normal no matter if i accelerate or let off the gas to stop the loss because it still happens as the rpm's erratically drop and come back. its not all the time that im driving it, just randomly and doesnt matter whether im climbing up or going down. im out of ideas here dont want really want to start looking for something else.
Old 05 Apr 2014, 03:52 pm
randyincctx's Avatar
Lightbulb Re: random issues i cant figure out
Replaced with Mopar or aftermarket?-(Aftermarket have a lower than average success rate,than genuine Mopar)
Another possible source could be the wiring harness itself(for CPS & CKS),the wiring harness for the CPS can sometimes get sandwiched between the coolant hoses,and eventually cause a breakdown of the insulation resulting in a fault,or flat-out short.....As for the CKS,it's wiring harness has been know to drop/hang down,and come into contact with the transaxle,thus wearing on the wiring harness,resulting in an intermittent ground fault/short.
To check either of those issues,you simply need to follow the harness/es from point 'A' to point 'B',giving them a thorough inspection.
Also,double-check the connectors....They can sometimes become loose(if not fully plugged-in on install),or get moisture in them(if dielectric grease isn't used)......But,sometimes simply un-plugging,then re-plugging them in,corrects an issue caused by poor connection.
Aka:~KILLER~
Old 10 Apr 2014, 03:24 pm
Default Re: random issues i cant figure out
well right now its dead. would an issue with the fuel pump even cause the crank or cam sensors to trigger?
Old 11 Apr 2014, 10:08 am
2step's Avatar
It's only just possible that your problem is fuel related. And there is no relationship with the cam and crank sensors and the fuel or fuel pump. I would check again for stored trouble codes. It could still be a sensor. I would also inspect the spark plugs and wires. You want to look for obvious things such as "Hey! The tip is missing on this plug." or "Hey! That wire was barely even on there." And if either haven't been changed in a long while, just go ahead and put in new ones. Those are the easy, inexpensive things to check and that's where you want to start, easy/cheap. It could be a number of other things, too, but those are a good, basic, first step.
Old 12 Apr 2014, 02:03 pm
well i took a chance and bought a mopar crank sensor for 73. problem solved.
Old 12 Apr 2014, 02:09 pm
Cool Re: random issues i cant figure out
WOW.....Imagine that;Another one for the record books.......All of that caused by an aftermarket CKS.
Glad you got it fixed.
Aka:~KILLER~
Old 12 Apr 2014, 03:00 pm
Nitro...are you listening?
randyincctx likes this.
Help I cant figure this out jkgx777 General Turbo Discussions 10 14 Nov 2013 11:46 pm
figure This one out scatgo Tech & Performance Forum 7 12 Oct 2013 05:34 pm
i cant figure it out agto Tech & Performance Forum 18 10 Mar 2012 08:59 pm
