CANT GAP IRIDIUM PLUGS?
Old 05 Apr 2014, 03:53 pm
Default CANT GAP IRIDIUM PLUGS?
the guy at auto-zone said if i gap iridium plugs they'll mis-fire i have 1 stage colder cause im gonna tune her to hell, and i thought she needed 40 gap, they come 50 gap????? please help asap im doing this job now, i can do rad flush/t stat swap to kill time, but i have to tune up today, thanks guys
2005 PT CRUISER GT
Semper Fidelis!!!
Old 05 Apr 2014, 04:05 pm
randyincctx's Avatar
Lightbulb Re: CANT GAP IRIDIUM PLUGS?
Rule #1: "Don't believe everything the guys(or girls)@ A/Z tell you"....
That's a new one on me?(maybe I'm wrong)......I do know you really shouldn't use cheapy 'coin-style' gappers,or even feeler-gauges.....But,I thought any plug is gappable?(They gap them @ the S/P factory)
The best thing to use are 'gapping-pliers',especially on Platinum or Iridium,because to use anything less can bend or break the electrode.
Here is what I recommend for use on any spark plugs(very accurate & no damage!):
Accel 380700 Accel Spark Plug Gapping Pliers - Free Shipping on All Orders @ JEGS
You can find them cheaper,I just used that as an example.......
Found this from DENSO:
http://densoiridium.com/installationguide.php
Aka:~KILLER~
Old 05 Apr 2014, 05:47 pm
Default Re: CANT GAP IRIDIUM PLUGS?
IMO you should have stayed with stock heat range! "Performance tuning, also means doing spark plug evaluation before changing things like heat ranges and deciding on a gap. The democracy of suggested spark plug gap is not indicative to ones personal driving habits,condition of the engine and other modes directly effecting how spark plug will perform in the engine.
I would leave the gap as they came out of the box unless there is one by checking them is off from the others. It is very easy to damage the plug if you are not experienced in gaping those type.
It is always a good idea to learn to properly gap plug on a set of old ones. Learn how to get good 90 degree angles.
Old 05 Apr 2014, 06:00 pm
Also here's a note on spark plug gaps - Say start the gap at 45, run idle when warm, do some minor drive testing, see how it runs. Then close the gap to 35, see how that works. What I do is go back and forth to find the best performance for my plugs, and normally you need the engine hot and running idle so that you can get a better feel for how well it's idling.
Personally, I think sometimes those expensive plugs are just that, expensive. I don't see a lot of gain from them. If it's a turbo engine, you definitely want plugs that don't overheat - good solid cold plugs is what you want.
Mind you, this is all my opinion, which is just general common-sense. That is how I work on my car and why it got upped to 341 hp, 365 lb ft torque!!
Old 05 Apr 2014, 08:35 pm
lucky you, thats EXACTLY where i wanna be, my goal is 400hp at the tires!!!
2005 PT CRUISER GT
Semper Fidelis!!!
NGK iridium spark plugs chromer don Tech & Performance Forum 10 14 Jun 2011 12:44 pm
iridium plugs??? DARK270 Stage Turbo Kits 28 17 Jan 2010 04:02 pm
Champion Iridium Plugs rszappa1 Tech & Performance Forum 5 06 Feb 2006 08:09 am
Iridium Plugs luvmypt Tech & Performance Forum 9 19 Jul 2004 12:16 pm
Denso Iridium Plugs gsharrock Turbo Performance 2 22 Jun 2003 09:09 am
