Radiator Cap N/A engine 2.4 (Mr Gasket Thermocap 2471S)
Like Tree5Likes
Old 05 Apr 2014, 07:15 pm
Danny7627's Avatar
Default Radiator Cap N/A engine 2.4 (Mr Gasket Thermocap 2471S)
I have been looking at the Mr. Gasket # 2471 Thermocap 16PSI for the awhile and wanted one but web sites only list it for the earlier N/A PT's.
http://www.summitracing.com/parts/mr...er?prefilter=1
Confused:
My current Stant Lev-R-Vent Radiator Cap 10330 was listed as 16 PSI and was listed as compatible for my year and model.. Its been on a couple of years no issues.
http://www.summitracing.com/parts/sn...del/pt-cruiser.
I was a little worried to try the MR Gasket cap as it seemed to be a no go based upon on the various venders and their compatibility tools all which indicated that this cap for the 07 N/A Cruiser was not an option.
To further add to my confusion, the Mopar OEM replacement radiator cap
is listed at 17PSI...
Before, I bought the Mr. Gasket cap I read this on the "PT DO IT YOURSELF . NET"
ptdoityourself.net PTDIY.net - PT Cruiser Technical Library Part Forty One Q&A 1001 - 1025
" The cooling system is equipped with a pressure cap that releases built up pressure, maintaining a range of 97-124 kPa (14-18 psi). There is also a vent valve in the center of the cap. This valve also opens when the coolant is cooling and contracting, allowing coolant to return to radiator from coolant recovery container by vacuum through connecting hose. If the valve is stuck shut, the radiator hoses will be collapsed on cool down. Clean the vent valve to ensure proper sealing when boiling point is reached, or replace the radiator cap. See the Pit area for additional information..."
Based upon the above, I am assuming that 16 PSI is within acceptable range?
The Mr Gasket Thermocap is equipped with valve to let the coolant return coolant recovery bottle.
"THERMOCAP RADIATOR CAP with built in thermometerKnowing coolant temperature can help to prevent burn injuries. Thermocap, with its built-in calibrated thermometer, indicates the coolant temperature. This can be the difference between safely opening a radiator cap and serious injury from steam burns. Thermocap's integrated coolant reclamation valve works with all OEM coolant recovery systems. Radia tor coolant is bypassed to and siphoned from overflow bottle as appropriate. "
Auto Part Number 2471S From Mr. Gasket | StreetPerformance.com
Long story short, I bought the MR Gasket Thermocap at PEP boys today for
$23.00. I admit more for looks for the engine compartment and for the cool temperature gage.
I took the car out to my sisters out on long Island for an extended trip and returned home with no issues. I even ran the A/C for a bit. The dash temp gage behaved normally and the car ran perfect.
Now, you guys with better wrenching experience, please feel free to tell me if you think this was a bad idea!
A couple of dollars lost is better than an over-heating issue.
2008 Convertible Turbo -lite
2007 Touring N/A Boneyard
Old 05 Apr 2014, 07:24 pm
Default Re: Radiator Cap N/A engine 2.4 (Mr Gasket Thermocap 2471S)
Confused:
It will be fine.
randyincctx likes this.
Old 05 Apr 2014, 07:42 pm
"bling" is sometimes functional and 'kool".
Old 05 Apr 2014, 08:08 pm
randyincctx's Avatar
Talking Re: Radiator Cap N/A engine 2.4 (Mr Gasket Thermocap 2471S)
I want one with a clock in it!
Danny7627 likes this.
Aka:~KILLER~
Old 05 Apr 2014, 08:10 pm
Na, a tack would be better!
Old 05 Apr 2014, 08:22 pm
Danny7627's Avatar
It also comes in red and blue...lol
Old 05 Apr 2014, 11:29 pm
Handy_Cruiser's Avatar
Do they make one with a compass? I might need to stop and figure out where I am.
Old 29 May 2014, 09:37 pm
Red face Re: Radiator Cap N/A engine 2.4 (Mr Gasket Thermocap 2471S)
Confused:
I have the same Thermocap and I never put in my car because I have the same doubt
Old 29 May 2014, 09:51 pm
Old 30 May 2014, 04:59 am
Danny7627's Avatar
No problems with the MR gasket 16PSI. Car runs fine and the temp gage stays in the middle
Engine oil pan gasket epis Tech & Performance Forum 0 09 Mar 2014 04:14 pm
Radiator Shakes Once Engine Warms Up soundofbread General PT Cruiser Discussions 5 24 Sep 2013 02:34 pm
Radiator boilover may be head or gasket TheAnt Tech & Performance Forum 19 03 Jan 2012 02:56 pm
Gasket leak below Radiator Cap on '01 Cruiser BlueWoody Tech & Performance Forum 9 14 Oct 2010 12:17 pm
Head Gasket / Radiator issues Craicgirl General PT Cruiser Discussions 2 26 Sep 2009 07:23 am
