Revs limited at 2500.
Old 05 Apr 2014, 08:46 pm
Default Revs limited at 2500.
I have a 2008 automatic pt cruiser, and the revs are limited at 2500. I was searching around and it seems to be a semi common issue. I was wondering if this wire hanging beneath the car could be causing it, and what it was? I'm not exactly well versed with cars. Thank you.
Old 05 Apr 2014, 09:00 pm
Default Re: Revs limited at 2500.
Sounds like its in limp mode. Take it to autozone or something like that and check for codes
Old 05 Apr 2014, 09:02 pm
2500rpm limit / limp mode?
Old 05 Apr 2014, 09:05 pm
I'll have to take it up there tomorrow to get the codes. The cel is on. I'm really wondering what the wire hanging is. My friend says it looks like an o2 sensor.
Old 06 Apr 2014, 04:01 am
You don't need a scanner to check codes on 'Cruisers. Whatcha do is this:
Insert the key into the ignition. One click, you're in the OFF position. Two, you should be in the RUN position.
Cycle the key from OFF to RUN in the following order, starting at OFF:
(Start at OFF)-RUN-OFF-RUN-OFF-RUN
Or, in other words, click it on,then back off, three times, holding in the on position to end.
Delay between each click for about half a second- I've found that if I do it too fast, it doesn't work. But on the other end, it all needs to be done within five seconds.
If it's done right, all codes are displayed on the odometer.
If you have one that says P0700, then I'd say limp mode is a safe guess. If it never, ever shifts, then it's probably locked into second gear.
I'm ALWAYS checking this weekly, at the same time as my oil and coolant checking.
Onyx Green PT Cruiser Touring; Totaled @ 174k
Old 06 Apr 2014, 10:24 am
I don't think you want to be driving around with that wire dragging on the floor.
Anyone who hasn't done so, PLEASE VIEW THE PHOTO THAT THEY POSTED to help identify what that is that is dragging on the ground.
It kind of looks important:
Old 06 Apr 2014, 10:47 am
Uhhhh yes you do, that key dance doesn't catch everything
And I know from experience, I am not parroting what I have read
Old 06 Apr 2014, 10:52 am
I did the key check, and no codes popped up. Just flashed done.
Old 06 Apr 2014, 11:04 am
I think you really need to figure out what the heck that wire / sensor / thingamajig is that is dragging beneath the car.
Anybody know what that is???
Old 06 Apr 2014, 11:36 am
This one should be easy. That's a light cable by the looks of it, probably for a fog light. That's a 9006/9005 connector.
04 GT for $2500 InfernoGT craigslist 4 29 Jan 2014 11:12 pm
Won't run above 2500 RPM Ikster General Turbo Discussions 5 25 Mar 2012 02:27 pm
better MPG @ rpm < 2500 PTC06Peet General PT Cruiser Discussions 1 13 Jun 2009 03:02 pm
GT PT will not go over 2500 RPM jerrys Turbo Performance 6 20 Aug 2008 09:35 am
Pop and backfire,2500-3000 RPM puptote Stage Turbo Kits 15 25 May 2007 06:58 am
