Check Engine Codes
Old 12 Apr 2014, 06:08 pm
Default Check Engine Codes
Our 2004 Turbo Cruiser is throwing PO300 & PO304 codes. Should I change SP wires, SP's, Ignition Module, or all of them together?????
2004 Platinum Edition 2.4 Turbo 291,000 Miles Owner since 2008 Great car!!!
Old 12 Apr 2014, 07:05 pm
Default Re: Check Engine Codes
Start with plugs and wires - the stock Champion plugs are fine, gap at 0.040.
Stock wires don't last - I like Crane wires
http://www.summitracing.com/parts/cr...4040/overview/
That usually fixes it, you might be "lucky" and need intake gasket.
Stock coil usually lasts a long time.
Old 12 Apr 2014, 11:40 pm
Thanks quicksilverdon, that was my first thought also. I'll check the plugs when I replace the wires and see if that cures the codes. If not then plugs. The existing wires are about 100,000 miles old. I'll post the results.
Old 13 Apr 2014, 08:34 am
I always do plugs and wires at same time. Hell yes, you need new wires.
Old 13 Apr 2014, 12:23 pm
Well, duh!!! [on my part]
Old 13 Apr 2014, 07:15 pm
New plugs and wires installed today. This went smooth and quick, since our PT Cruiser is a turbo model, it isn't necessary to remove the intake manifold as it is with the non-turbo.
Installed the plugs and wires and went for a test drive!! 30 seconds and the check engine light comes on with its "ping" alert noise. I drove to an area where I could check the code with the OBDII reader and it was a PO300, random misfire. I erased the code and drove about 10 miles in all driving conditions, slow, fast and idle. No more codes.
We'll see how it goes over the next week before I do anything else.
Old 02 May 2014, 11:02 am
thecabinguy's Avatar
I know that I'm going to appear extra ignorant here, but I keep seeing a lot of posts about "throwing codes" and someone listing the code numbers. Where does one see the codes? I just read a post where someone saw three codes come up and were asking about them. How do we see them???
Prescott, Arizona, home of forested mountains, 5 lakes (well, four lakes and one big pond), and Arizona's Christmas City (my home 6,000 feet elevation) - 2005 Touring & 2002 Limited - both patriot blue & factory stock
Old 02 May 2014, 11:22 am
if you don't have a reader, without starting turn the key on off, on off, on. the codes will pop up in the odometer. I have to do it a few times as it doesn't work right off the bat.
check for the "key dance" in the tech "how to" section.
2016 Kia Soul Plus Black
Old 02 May 2014, 02:47 pm
Link to click on....
How to retrieve fault codes.
Old 04 May 2014, 05:00 pm
I just tried the three times turning the key within 5 seconds and, lo and behold, the word "done" came up, no codes. Amazing, I have had this car 9 years and I never knew anything about this? Man, how ignorant can an owner be. Thanks, CREWZIN.
06 stalled twice, check engine, no codes rrolff General PT Cruiser Discussions 3 24 May 2013 05:10 pm
Different check engine codes Jkraft0531 Tech & Performance Forum 1 06 Apr 2013 10:06 am
No Codes yet check engine and oil light won't go off Simple2sing General Turbo Discussions 2 26 Mar 2009 07:26 pm
Engine check on / Codes Krzysztof General PT Cruiser Discussions 1 16 Apr 2007 09:37 am
Check engine light on - & NO CODES?!?! CraigO Turbo Performance 9 20 Dec 2003 02:42 am
