Greetings fellow Cruisers!
OK, so the T belt in my 05 quit on the highway @ 70mph, I coasted off the roadway and like a dummy I cranked the engine over,..........nothing. So it's home in my shop and the engine is out and on the stand. I removed the valve cover and the timing belt cover and pulled out the old belt,....a clean break. I set the engine up at TDC on #1, made sure the cams were turned so the valves were in the closed position and put air to the cylinder, about 100 psi. There is a small bit of air coming out of the intake port and a lot out of the exaust port. I repeated the process for 2,3 and 4 and got basically the same results except on 3 where the leakage is on the intake side. Bent or burned or both ?????? I also got a rattle noise when I plugged the air into 3 and 4. What could that be ?? It's my first Cruiser engine repair. Thanks for any help. |
You need a need timing belt, water pump and tensioner pulleys.
doing a compression check without a belt doesn't provide useful information
Useful Documents Useful How-To's Have an engine code? Sometimes this link is helpful Neon Bobble Strut ^^ Click |
Thread Tools | |
Display Modes | |
timing belt question | bigsquat | Tech & Performance Forum | 15 | 25 Mar 2014 05:40 pm |
Timing belt question | Dermodad | Tech & Performance Forum | 16 | 15 Aug 2013 05:02 pm |
timing belt question | rob619 | Tech & Performance Forum | 3 | 09 Nov 2012 01:45 am |
Timing belt question | maddyfan171 | General PT Cruiser Discussions | 9 | 19 Aug 2011 11:03 pm |
Timing belt question | slimjonesy | Tech & Performance Forum | 10 | 18 Jun 2011 04:30 pm |
