code po 420
Old 20 Apr 2014, 01:34 pm
Default code po 420
getting this code and from looking at the fault code list else where on this site i have either a faulty lambda sensor or a failing cat.
now the sensor will be my first port of call to fix this code but after a Google search i find that there a afew manufacturers of these and this has left me a little confused as to what would be the correct one to get
ok car is
2004 2.l classic with 107k miles on the clock full dealer stamped history and cambelt done at 96k miles. car is in all round good conditin and have had independant mechanic look at car and all is good with suspension brakes etc .
lots of new parts including new fuel tank at some point in the not to disant past as the white paper sticker that is on the bottom is still clean and fully readable.
is there a "howto " on replaceing the rear o2 sensor or a wrong way to do it? or is it a simple spanner and penetrating spray then unplug and repeat to install the new part?
any hel advice or just plain daft answers welcome
Old 20 Apr 2014, 07:03 pm
randyincctx's Avatar
Lightbulb Re: code po 420
It's fairly easy,and straight-forward.....My main tip would be to pick up a can of PB Blaster,and saturate the nuts really good and give it time to penetrate(let IT do the hard work 4 U!);The rest of the tips you can find in this video,since the O2 sensor for Dodge Neon,is virtually the same:
Aka:~KILLER~
Old 21 Apr 2014, 06:01 am
Default Re: code po 420
ok thats a simple and straigt forward swap out , just need to find the correct o2 sensor now and then get it done, any ideas on what sensor it should be?
P0420 code Converter Code? 2008/110,000 miles Sarasmiles Tech & Performance Forum 8 28 Mar 2014 07:08 pm
CODE P0339 NOW, NOT "ALL" FIXED CODE YET HarleyTom Tech & Performance Forum 0 14 Nov 2012 03:23 pm
Code 320. 300 brklnnite718 Tech & Performance Forum 6 16 Jul 2009 08:34 am
what is this code medtwo Tech & Performance Forum 2 04 Dec 2008 07:54 am
Code Help! 1lowufo Tech & Performance Forum 1 21 Aug 2004 07:03 pm
