2001 PT Cruiser
  • 1 Post By CREWZIN
Old 21 Apr 2014, 11:56 am
Default 2001 PT Cruiser
Where is the EGR valve located ?
Old 21 Apr 2014, 12:56 pm
Default Re: 2001 PT Cruiser
OK, see this EGR pipe in the back of the upper manifold?
If you follow that down to the right hand side of the engine while standing in front, that pipe will lead you directly to the EGR valve which is attached to the other end of that pipe.
boonie2 likes this.
Old 21 Apr 2014, 03:37 pm
If you are replacing the EGR valve, I found it was easier to remove the two bolts (circled in red) in the top picture holding the tube, and then the two bolts holding the EGR valve to the engine (B) , then remove the tube from the EGR valve once you have the whole assembly out than trying to remove the bolts to the tube while it was in the car.
You need to remove the airbox to get to it, and if you loosen the bolts to the whatchamacallit (power distribution center?) below the airbox to allow it to move some, it is a little easier to get a ratchet onto the bolts for the EGR.
2001 pt cruiser please help RogenskiAmanda General PT Cruiser Discussions 4 02 Dec 2011 12:52 pm
2001 PT Cruiser Teckspeed General PT Cruiser Discussions 10 02 Jul 2011 08:44 pm
2001 PT Cruiser getting hot please help!!! jtsebastian Tech & Performance Forum 1 15 Dec 2010 06:13 am
