2001 PT cruiser code P0401
Old 21 Apr 2014, 02:55 pm
Default 2001 PT cruiser code P0401
Thank you for the location. Now the questions. I gather that is a diaphram on the top and that a tube may go to the switch. Can I take this apart and clean it out? If this works how do I cancel the engine light and code ? Could it be a faulty switch and can that be replaced. How would you test it? Thank you
whirlinwilly
Old 21 Apr 2014, 03:42 pm
Default Re: 2001 PT cruiser code P0401
When I got the code and replaced the valve, I discovered that the metal tube to it was pretty much clogged - that may have been the problem instead of the valve itself being bad. I cleaned it out and put on the new valve. Disconnecting the battery removed the code for me and it has not come back after 3 years or so.
Malfunction Indicator with P0401 code Patrick_Dickey Tech & Performance Forum 17 26 Feb 2018 04:05 pm
2001 pt cruiser died code 320 Chrisd069 General PT Cruiser Discussions 7 11 May 2013 01:31 am
2001 pt cruiser p0700 code Ginz General PT Cruiser Discussions 8 14 Aug 2010 11:05 am
code P0401 jmrcmama Tech & Performance Forum 2 12 Apr 2010 05:42 pm
UGH! Code 0442, PT Cruiser 2001 LTD, 41,000 miles tvldeals General PT Cruiser Discussions 5 08 Aug 2005 12:46 am
