More Cooling system questions
  • 1 Post By thecabinguy
Old 22 Apr 2014, 09:59 am
Default More Cooling system questions
Hi Folks.
I'm still confused with our PTs cooling system.
We bought our secondhand 2.0l auto second hand a couple of weeks ago.
The first weekend we had it - it got quite hot - but I shut it off before it got anywhere near the red.
After that - I found the coolant in the system to be a bit low - although the expansion tank was full.
We gave it back to the dealer - who ran it for a couple of days - it never got hot again - and they had a garage check it - and it didn't get hot either.
I put a new radiator cap on.
This weekend I checked that the fan was coming on after testing the relays. It does - just about when the temp needle nudges over half way.
When left idling the temp rises to half - then at just over half the fan kick in.
If I rev the engine though the temp drops to where it seems to normally sit which is at roughly 4 o'clock.
When driving temp varies between 4 o'clock and half - half in slow traffic.
Am I right in thinking half way is the normal position?
taking this into account - the thermostat was changed last October - could it have been a faulty one - as my diagnosis would seem to suggest it's running a bit cold??
Thanks..
Old 22 Apr 2014, 10:31 am
thecabinguy's Avatar
Default Re: More Cooling system questions
Originally Posted by euphonium_john View Post
Hi Folks.
Thanks..
Have two PT Cruisers and they both run exactly at the halfway temp mark when fully warmed up, rarely seems to vary.
Prescott, Arizona, home of forested mountains, 5 lakes (well, four lakes and one big pond), and Arizona's Christmas City (my home 6,000 feet elevation) - 2005 Touring & 2002 Limited - both patriot blue & factory stock
Old 22 Apr 2014, 11:10 am
Same here with both my PTs. 1/2 mark on gauge and stays there.
You may have gotten a slightly cooler thermostat.
Help with cooling system!! Osufan64 Tech & Performance Forum 3 29 Oct 2013 01:09 pm
03 gt turbo cooling system...help !!! SteveisKoolaid General Turbo Discussions 5 26 Jul 2013 10:00 pm
Cooling system noises BlueWoody Tech & Performance Forum 7 17 May 2012 08:18 pm
cooling system problems BeagleDad Tech & Performance Forum 6 15 May 2010 03:58 am
cooling system ? cllwyrc Tech & Performance Forum 6 25 Apr 2010 10:35 pm
