P031 and P037 Codes
Old 22 Apr 2014, 10:15 pm
Default P031 and P037 Codes
As I understand it, these codes are related to the O2 sensors, which makes sense, because the car is running very poorly and almost dies, so I assume the fuel mix is getting messed up.
So, a couple of questions for y'all:
1) I NEVER had these codes before replacing the PCM last fall. Immediately after replacing I got these codes, but was able to clear them. But, now they keep coming back. So....should I just replace the PCM again and save myself the hassle of trying to solve a "new" problem?
2) Is there an easy test to check if the sensors are actually bad so I can feel better about sending back the PCM for a replacement?
Thanks for your help!
what do these codes mean byrne_266 Tech & Performance Forum 12 21 Feb 2014 04:23 pm
Dash codes--not the usual OBD codes--help! chitowncruiser General PT Cruiser Discussions 5 01 Mar 2013 11:56 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
TOO MANY CODES!!! Nonie Tech & Performance Forum 13 20 Mar 2011 12:21 am
