01 Cruiser Horn problem
Old 23 Apr 2014, 09:44 pm
Default 01 Cruiser Horn problem
Horn was intermittent last year then just stopped working. So i just got around to caring about it after dealing with all the other issues my car has been through. So heres what I did so far. I Pulled the horn relay and put the multimeter on the female receptacle side couldnt get voltage with the car horn being pressed. Tried every possible combo but no juice. So for giggles I got to the horn and made sure it wasn't a lose contact by checking the cables with the meter those were good. So im losing power somewhere from the horn on the wheel to the relay under the hood. What else should I check?
Old 24 Apr 2014, 05:49 am
Default Re: 01 Cruiser Horn problem
You can check the horn fuse, No#14 in the PDC under the hood and the horn electrical connection in the steering wheel.
Old 24 Apr 2014, 09:26 am
Yeah the horn relay/fuse under the hood is what i checked. I guess i can try and take the cover off the steering wheel and check that...this should be fun Just thought about this for a second, when i press the lock button on my car alarm the car horn doesn't sound either "it usually does". So that would lead me to believe its not related directly to pushing down on the steering wheel horn.
Old 24 Apr 2014, 10:12 am
So I solved the year old problem. It threw me for a loop when I tested the relay under the hood for the 8 ohm resistance It appeared fine on my MM. So out of curiosity i switched it with the starter relay "same make same model #" and car wouldnt start! So I guess it was the relay this whole time....smh Now If i could just figure out why every local car parts place wants $20 for a replacement when eBay sells them for an avg of $8! Waiting until i get the replacement now cause I'm not paying triple for the same stupid relay.
Old 24 Apr 2014, 10:21 am
Glad you got it figured out before pulling the air bag module on the steering wheel.
Horn Problem 2007 Cruiser crandon71 General PT Cruiser Discussions 8 15 Jul 2017 02:22 pm
Horn button problem??? vetteloverpa General PT Cruiser Discussions 20 24 Sep 2014 03:27 pm
2005 Horn problem crzn45 Sound and Security Forum 1 11 Dec 2010 04:25 am
Horn problem! Need help jddaero05 General PT Cruiser Discussions 5 17 Oct 2010 11:05 pm
Wierd Horn Problem digitalpinscruiser Tech & Performance Forum 3 07 Jun 2008 06:23 am
