AC Intermittent Cold then Hot
Old 24 Apr 2014, 10:32 pm
Cool AC Intermittent Cold then Hot
Hey any help would be greatly appreciated. I searched the forum and didnt find anything exactly like what I have going on. 2001 PT Cruiser (non turbo) 160K
Ok, so in the mornings my engine is cold and the AC appears to be blowing cold & is perfectly fine. After about 40 minutes of driving I can feel a drop in temperature but still cool, it will then return to cold and then drop again about 15 minutes later to warm and this cycle repeats.
Late afternoon, I leave work and the AC is blowing HOT! Even if the engine is cool. This seems to happen mostly when it is 85+ outside. If the outside temperature is not that hot, the AC will blow cold/warm/cool as mentioned above (intermittently).
The rad fan seems to be functioning fine while idle and the changes in AC temp do not seem to be different at idle or at highway driving. I do not seem to be having any overheating issues and the temp gauge never goes above halfway.
Suggestions? Thanks alot everyone!
Old 24 Apr 2014, 11:07 pm
Default Re: AC Intermittent Cold then Hot
my 01 limited done the same thing .mine was low on refrigerant. added refrigerant and it works good.
Old 24 Apr 2014, 11:15 pm
Cool thanks man
Old 25 Apr 2014, 08:23 am
Could be your cooling fan isn't working all the time when the air is on.
Old 25 Apr 2014, 08:28 am
He said,
"The rad fan seems to be functioning fine while idle and the changes in AC temp do not seem to be different at idle or at highway driving. I do not seem to be having any overheating issues and the temp gauge never goes above halfway."
I'd start with a recharge and go from there....
Old 25 Apr 2014, 08:41 am
Originally Posted by quicksilverdon View Post
He said,
If that's the case. There has to be a small leak. Should not lose Rrefrigerant. It's a closed system.
Tags
air conditioning
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
Intermittent overheat slipperyrock General PT Cruiser Discussions 4 02 Apr 2013 06:52 am
Intermittent window Traceyscar Tech & Performance Forum 1 07 Sep 2012 02:53 pm
Hot, cold, hot, cold...I'm freezing in here!!!! Ironman Tech & Performance Forum 8 07 Dec 2010 10:51 am
Cold Cold Crazy PianT General PT Cruiser Discussions 13 21 Jan 2004 11:35 pm
