gurgling in cooling system
Like Tree5Likes
  • 3 Post By rob342
  • 1 Post By bobubuntu
  • 1 Post By rob302
Old 25 Apr 2014, 12:14 pm
Default gurgling in cooling system
Have 2002 cruiser. Had water pump replaced last Nov. Was fine all winter and now since it starter getting warmer temps, get a gurgling sound near reserve tank. Was getting hot and replaced thermostat. Now doesn't get hot and only hear gurgling when shut off engine. Losing fluid, but no apparant leaks. Any suggestions.
Old 25 Apr 2014, 12:59 pm
Default Re: gurgling in cooling system
there's a good chance you have air in the system. on mine the thermostat housing had a small crack that I couldn't see, had the same symptoms as yours. replaced it and bled the system and no problems since then.
2016 Kia Soul Plus Black
Old 25 Apr 2014, 01:44 pm
mispep, welcome to the forum.
No apparent leaks could mean one of two things. A cracked head gasket or the small leak into a hot area where it turns to steam and disappears. A small leak will cause air to take it's place in the cooling system and cause gurgling and overheating. Cheapest place to start is a pressure check on the cooling system to find the leak.
Old 25 Apr 2014, 03:24 pm
I must have gotten at least a dozen pm's and 2 customers last year with this complaint. It was the radiator cap or the housing itself not sealing properly.
Like CREWZIN suggested a coolant pressure test followed up with a test for blown or cracked head. This is called a "block tester. Bo these test are very easy to do.
Old 25 Apr 2014, 03:45 pm
is this a block tester?
Old 03 Jul 2019, 01:46 am
Gurgling is a sure sign of an air pocket in the engine. On a COLD engine, loosen the block bleeder nozzle (3/8 socket) located on the thermostat housing under the filler neck. slip a 2 ft piece of clear plastic tubing onto the nozzle and feed it into a clear bottle so you can see the coolant as it runs into the bottle. pour fresh coolant into the radiator till no more air bubbles show in the tubing.
chuzz likes this.
Old 03 Jul 2019, 11:56 am
rob302's Avatar
little late to the party, bob.
VsandFords likes this.
Help with cooling system!! Osufan64 Tech & Performance Forum 3 29 Oct 2013 01:09 pm
03 gt turbo cooling system...help !!! SteveisKoolaid General Turbo Discussions 5 26 Jul 2013 10:00 pm
Cooling system noises BlueWoody Tech & Performance Forum 7 17 May 2012 08:18 pm
cooling system problems BeagleDad Tech & Performance Forum 6 15 May 2010 03:58 am
cooling system ? cllwyrc Tech & Performance Forum 6 25 Apr 2010 10:35 pm
