'03 Cruiser GT engine not cranking
  • 1 Post By johnnybassman
Old 27 Apr 2014, 05:41 pm
Default '03 Cruiser GT engine not cranking
Hi all,
A little over two weeks ago my 2003 PT Cruiser would not start. There was still power to the lights and dash, but the engine would not crank at all. A fuse had blown (20 amp Fuel Pump/ASD fuse), the fuse was replaced and the car started.
Just a week later, the fuse blew again, however this time replacing the fuse isn't working, it just continues to blow.
The relays appear to be working, though when I pull the ASD relay and turn key to ignition the engine cranks. So, I'm thinking there is a short someplace. Judging from the wiring diagrams I have, it looks like the relay goes to the PCM from there.
However, while checking wiring, I found something that appears to have been attached to the back of the engine block, on the left half. I have attached pics of what I found. I have no idea what this is for, and don't want to make an assumption as to where it was attached, but I can feel what appears to be a screw hole in the engine block, and as shown in the pics, the connection looks a little burnt.
Any thoughts? Any help is greatly appreciated.
Old 27 Apr 2014, 06:16 pm
Default Re: '03 Cruiser GT engine not cranking
A couple more pics, this is from the back of the engine block where I believe the connection should be.
Old 27 Apr 2014, 06:34 pm
If that hole IS where that connection should be, it means that set of wires should be grounded to the block. Since it's not grounded, that connection could be intermittently grounding on the part that it's touching and causing the ASD fuse to blow each time it touches. Just a guess on my part.
Also take that connection and look/move it around carefully to see any other place it might have come detached from.
Old 27 Apr 2014, 07:38 pm
Looks like it got down on the exhaust. If that didn't happen Then most likely the tab acts as a heat sink and being loose caused it to fry.
Old 27 Apr 2014, 07:53 pm
randyincctx's Avatar
Post Re: '03 Cruiser GT engine not cranking
Originally Posted by johnnybassman View Post
The relay appear to be working
Judging a relay by appearance isn't a very good method......One simple way to confirm if a relay is bad or not,is to take another relay(horn relay in your case),and swap them out;Does the car start,and the horn not work now?...If no difference,then the relays are both good;The only other way to check a relay properly,is with the use of a multimeter(continuity?).
As for the photos you posted,that is a capacitor for the 'Ignition/Radio Noise Suppressor'(part# 04606866AA),and it is supposed to be mounted/grounded to the engine w/M6x1.00 bolt,just below the throttle body,and to the left of the PDC(when standing in front).
That may,or may not be the reason for your issue,but it sure isn't helping it.
Check here for more info:
Loose connector - Green with Orange Stripe
Aka:~KILLER~
Old 27 Apr 2014, 08:31 pm
Actually I tested the Fuel Pump and ASD relays by swapping them with the horn relay and honking the horn. They all worked. Also, tried to start the car with the fuel pump relay removed and the fuse blew, then started the car with the ASD relay removed and the car cranked but didn't start and the fuse remained viable.
I'll pop into the dealer tomorrow to pick up a replacement capacitor and bolt. The bolt must have vibrated out? Very weird.
randyincctx likes this.
Old 27 Apr 2014, 08:49 pm
Cool Re: '03 Cruiser GT engine not cranking
That's plausible,or someone had removed it during the course of a repair/service,and just forgot to put it back......But,you were able to locate the proper placement from my description and/or the photos in the thread I posted,right?
Aka:~KILLER~
Old 27 Apr 2014, 08:53 pm
I did indeed! I don't have a bolt but I'll get one when I get the replacement capacitor tomorrow.
Thank you very much!
Old 30 Apr 2014, 06:06 pm
Good news! Replacing the capacitor was the trick, the car fired up right away. The bad news: now getting error code P0480 (Cooling Fan Relay 1 Control Circuit), so now I need to check that. I test drove the car and with all the climate controls off I didn't notice the engine temp climbing about midway, which is right. Drove it for 15 minutes like that before I turned on the A/C, 5 minutes later the needle was inching towards the red.
Old 01 May 2014, 07:42 am
Ground locations question
Originally Posted by Hearse View Post
Bolts to the intake manifold support bracket on mine.
2003 GT- Stage 1, Mopar BOV, 2.75" catback, Hurst SS, Eibach pro-kit, 6000k fogs, Alpine CDA 7893, 10" Alpine Type-X powered with JL Audio e1400d, Alpine Type-R components powered with JL Audio e4300.
Cranking, no fire. won't start! TDragonkirs General PT Cruiser Discussions 12 22 Nov 2013 02:16 pm
Not cranking but have power eline65 General PT Cruiser Discussions 39 10 Sep 2013 03:31 am
PT Won't Start, No Codes, No Cranking... pink_lemur13 General PT Cruiser Discussions 4 06 Apr 2013 11:39 am
Cranking but not starting. SiRPt3 Tech & Performance Forum 2 23 Dec 2010 10:00 pm
long cranking 4b316 Tech & Performance Forum 3 05 Aug 2008 07:34 am
