Guys need help
Old 15 Apr 2004, 11:15 am
Default Guys need help
hello guys, am new here and i hope i am welcomed
i have a problem and i hope u can help me, Guys am not sure of its something wrong, but i opened up the airfilter cover and removed the filter from its place, i was just checking it out, and i placed it again and closed it. AS i was heading back home i floored it once, and then after 10 kms i heard this weird noise coming out of the engine, its like the engine has a new ROAR , sounds different, high noise.
Another thing happened as i reached home, the passenger seat next to the driver, under the glove box, something fell, but it is still attached, i tried to put it up again but i couldnt, it doesnt move..
so what shall i do .... need help fast
Old 15 Apr 2004, 11:20 am
junkno,
You look familiar, welcome to the links. Many people on here are nice and friendly, and some just like to joke around from time to time.
About the roar thing in your engine. Mine did the same when I first checked the filter. Are you sure you got the back 4 notches in the proper holes. There located on the bottom part of the box in the back and near the top. You will not notice them unless you are looking for them. They hook into the top half of the box. Hope that helps some.
Im not sure about the underseat thing. [:I]
Kingkole02
Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics
Old 15 Apr 2004, 11:23 am
Be warned!!!!!
Now that you have joined you will also be spending lots of money on aftermarkets parts. []
Kingkole02
Old 15 Apr 2004, 11:28 am
am also in ptcw
am sure i attached it correctly, and btw, whats with the high sound, will it go away? [:I][:I]
Am saving up for some cash, am still a university student (first year)
Old 15 Apr 2004, 11:39 am
about the under glove thing, it is right here
Old 15 Apr 2004, 12:03 pm
Did you check it a second time after what I told you to check? I think that maybe the filter isn't set right if the box is on correctly. It should fit snuggley on the sides but not tight.
Were there any tools you might have used? If so check for them and see if one may be missing.
I don't really know about the high sound. Mine had a low roary sound until I had fixed the box and set it right.
About the part falling, is there anything in the glove box that might have moved causing the same sound?
Kingkole02
Old 15 Apr 2004, 01:10 pm
junkno, welcome to the forum. I agree with KingKole, sounds like the filter isn't set right or the box isn't sealed properly. Not sure about the item that fell down under the glove box, what does it look like?
2002 Inferno Red PT Limited
Mercedes Wiki
Old 15 Apr 2004, 05:40 pm
thx for the help guys, i placed it correctly now (but u know the sound was kinda cool though,btw do you guys know what happens if i left it the way it is [:I])
About the peace under the glove box, my friend tells me its the Heater Core ??! [:I]
Old 15 Apr 2004, 05:44 pm
Yes, you suck all sorts of bad things into your intake and into the combustion chambers which is not good.
If you like the noise, get a cold air filter like an AirRaid or a K&N.
That helps low end throttle response, pep the car up a bit, esp if its a non-turbo. If it's a turbo, your better off with the box and a drop in filter unless you go ram air.
You got a pic of the thing that fell below the glove box?
Homepage:
Old 15 Apr 2004, 05:53 pm
i will get a pic of it tomorow hopefully,
Am not that experienced with cars so i was just wondering, when i went for my 6000 kms oil change, etc.., i asked the guy if i can put an exhaust, only cat back and he was like saying it will ruin ur warranty , and i saw some k&n filters just the cones, which size should i get , there were like different sizes
Any of you guys live in or near the Tampa Area? SuGamer Southeast PT Forum 3 19 Nov 2004 02:07 pm
what do you guys think? Punch Non-PT Discussions 21 25 Jan 2004 07:30 pm
What do you guys want? Exhaust Depot General Turbo Discussions 28 04 Sep 2003 11:48 pm
Hey guys turbomangt General PT Cruiser Discussions 4 05 Aug 2003 10:06 am
Talked to the guys at AGP !!! COP TZER Turbo Performance 10 17 Jul 2003 01:14 am
