2003 PT Cruiser died
Old 04 May 2014, 06:24 am
Unhappy 2003 PT Cruiser died
I was leaving work Thursday morning when my 2003 PT Cruiser with 105k miles died at the end of the short street my work is on, when I was about to turn on the main road. Couldn't get it restarted so I had it towed home. I disconnected the battery to reset the codes, and tried to restart the car. When that didn't work I did the key dance to get the engine code which only had P0340 showing up which is the camshaft sensor. I replaced the sensor, and the car still won't start up. With the sensor off I could see that the camshaft turning. I cleared the codes again, and this time I'm getting P0340 AND P0339 codes. I know P0339 is the crankshaft sensor, so both sensors going bad at the same time is a possibility, but the odds are they both wouldn't go bad at the same time. I'm at a loss on how to go from here, I'm thinking maybe a wire might be broke somewhere that's now causing both sensors to not behave. Thanks.
Old 04 May 2014, 08:56 am
Default Re: 2003 PT Cruiser died
I'm sure that the belt is the issue. If the cam is still rotating you may have stripped some teeth. Could be far enough out to trigger those codes. Pull the top cover to get a visual on the belt. The screws in the back on the rear or firewall end.
Old 04 May 2014, 09:37 am
Got it running! Turns out the one wiring harness to the computer had a broken tab which allowed it to wiggle loose. Pushed it in and it fired right up.
Old 04 May 2014, 09:41 am
That's unusual. Post a pick of that for future references for others.
Old 04 May 2014, 06:31 pm
You are lucky.
Better plan on having the timing belt & water pump done - it's due....
2002 PT Cruiser died--Help! ikagram Midwest PT Forum 0 26 Aug 2012 05:02 pm
2003 PT Cruiser died while driving tlm Tech & Performance Forum 6 24 Sep 2011 01:47 pm
Cruiser Died MomsCruser Tech & Performance Forum 15 13 Feb 2011 12:46 am
2003 PT Died on the road.... trerrick Tech & Performance Forum 2 29 Dec 2009 06:49 am
My Cruiser just died HELP sfctgshort Tech & Performance Forum 6 19 Aug 2005 07:30 am
