PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/tech-performance-forum/)
-   -   GT Performance Rethink - a new plan? (http://www.ptcruiserlinks.com/forum/tech-performance-forum/52868-gt-performance-rethink-new-plan.html)
Kevhead 04 May 2014 09:34 am
Need adise from the PT Pros!
I have an 04 GT. Mods are ST1 Module, ST2 Wastegate Actuator, Mopar BOV, Airforce One Cold Air, Mopar Cat-Back, Suncoast Ram-Air hood. I am showing between 13-15 lb. of boost, but at WOT the injector duty cycle is @89-93%. A Dynojet revealed that the air/fuel mixture was lean. This is my plan - first switch out the ST1 Module and ST2 Actuator and go back to the originals, purchase the Diablosport Intune and install the canned 93 tune, and recheck the injector duty cycle. If it's still high install 650cc or 750cc injectors, check the duty cycle again, have it dyno'd, and then if it's still lean consider installing a wideband and a custom tune. I don't have a large budget, and I'm thinking if I take the Intune step and possibly upgrade the injectors I may be able to fix the lean issue and get the same or better performance I have now. Thoughts?
Busted_PT 04 May 2014 09:39 am
Re: GT Performance Rethink - a new plan?
PM Lynn (AKA) NitroPT
apexanimal 04 May 2014 02:23 pm
You should really have a wideband regardless if you're playing around with this stuff...
IMHO, that would be priority one... Then do some data logging and find out what is going on for sure....
Then let us know what you find and well sort through it from there...
NitroPT 04 May 2014 05:08 pm
Danny he did om me and we are working on a simple solutions that he won't have to spend any un-necessary money and will need for his PT with the upgrades he has and in the future. ;)
I do agree with Scott, an Air Fuel Ratio gauge is really a must when you start doing out of the box engine upgrades.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
