2001 PT Cruiser LE
Old 05 May 2014, 06:22 pm
commosutra's Avatar
Default 2001 PT Cruiser LE
I recently got this car from my dad after he passed away, I drove it from Illinois to Georgia and while in route, The ABS and Break lights came on, I got it looked at and the nothing could be found. About 3 days later. I was backing out of a parking lot and it died. I tried to crank it and it would turn over, but not fire. So i did the dodge dance and it came up with, cam sensor, so i replaced it, and again tried to crank, after about 15 seconds, it started and ran rough for about 10 seconds and dies again, I did the dance again and got a crankshaft sensor error, so i had a tow truck pick it up. The garage replaced it and cleared the codes, and it wouldn't start, so they said they swapped the coil pack and it still wouldn't start, now they think it's the ICM and said the part is $600, I cannot find a ICM listed anywhere in the manuals.
Any suggestions?
Old 05 May 2014, 06:30 pm
Default Re: 2001 PT Cruiser LE
Sounds like the timing belt jumped a tooth or two
Silver Bullet - 2001 PT Cruiser Limited, 5-Speed, 2.4 N/A, No mods yet just fixing her up slowly
Old 05 May 2014, 06:31 pm
boonie2's Avatar
How many miles on it ? It COULD be the timing belt
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 05 May 2014, 06:40 pm
Agree with others.
You need to move your car to a competent shop.
Why would they replace the coil? Nothing indicates coil was bad.
They are just throwing parts and guessing....
Old 05 May 2014, 06:51 pm
Any suggestions?
Check the wiring harness between the crank sensor and the cam sensor. Most likely the parts were good to begin with. On that model it can come loose and rub the axle or something. CREWZEN had this very thing happen to him. Please let us know the outcome of this.
Old 05 May 2014, 07:19 pm
Originally Posted by Busted_PT View Post
Check the harness between the crank sensor and the cam sensor. Most likely the parts were good to begin with. On that model it can come loose and rub the axle or something. CREWZEN had this very thing happen to him. Please let us know the outcome of this.
happened to me as well. something about the '01
2016 Kia Soul Plus Black
Old 05 May 2014, 07:34 pm
commosutra's Avatar
Its got 144,000 Ill ask them to check the Timing belt, and let everyone know the outcome. Thanks for the fast response
Old 06 May 2014, 05:54 am
commosutra's Avatar
Real quick question, does the cruiser have a Ignition Control Module ?
Old 06 May 2014, 08:38 am
If the wiring that I mentioned is damaged you won't have Ignition or fuel delivery. That dictated by the timing and that is done with the crank and cam sensors. We just had a person on here a few days ago with that problem on a later model.
Old 07 May 2014, 05:29 pm
can someone link the thread from last week. what wire should i be checking
My 2001 PT Cruiser garykohl2 Members PT Project 13 25 Jan 2016 03:13 pm
2001 PT Cruiser whirlinwilly Tech & Performance Forum 2 21 Apr 2014 03:37 pm
2001 PT Cruiser KDS111 General PT Cruiser Discussions 3 08 Aug 2012 11:39 am
2001 PT Cruiser Teckspeed General PT Cruiser Discussions 10 02 Jul 2011 08:44 pm
2001 PT cruiser rim ericamao Wheels, Tires, Suspension 1 03 Dec 2010 05:47 pm
