No power steering and battery light
Old 06 May 2014, 02:55 pm
Default No power steering and battery light
We have a 2001 pt cruiser, the other day we started the car and went to pull out but the steering was very hard to turn, we went maybe 2 miles down the road and the battery light came on. Does that mean a belt broke? Is this a hard fix? What do you think a garage would charge? I'm also thinking we may need a new power steering pump since it seems to be leaking power steering fluid from somewhere.
Old 07 May 2014, 01:28 pm
Default Re: No power steering and battery light
bump please
Old 07 May 2014, 02:28 pm
cruserdad1976's Avatar
ok if the belt that runs the power steering broke yes you will loose power sterring so thats a could be
how hard is kind of depends on your skill level it is for sure a do it yourtself but its kind of a pain at the same time and probaly messy
You probaly need a hose rather than a power streeing pump, the hoses seem to leak more offten than the pumps quit
My guess at a shop for the power steering belt and the hose is around the $200 range??? could be wrong depends on the labor rate
How many miles are on your 2001???
Old 07 May 2014, 03:34 pm
We bought it with around 78,000 miles, right now I think its about 80,000
Old 07 May 2014, 03:48 pm
Sears and other places will test your battery and charging system for free - call ahead and be sure - and get a second opinion.
Old 07 May 2014, 05:53 pm
Handy_Cruiser's Avatar
There's about a 90% chance that your drive belt is gone. And many 2001 PT's seem to have a minor power steering leak. It's very likely the hose.
Old 07 May 2014, 05:56 pm
if you wanted you could power wash that area of the engin compartment and clean the hose up real good then keep checking to see where or what is leaking
Old 09 May 2014, 07:12 pm
Well the garage called to day and said they had to replace both belts because one was missing and the other one was torn, so that's all fixed BUT I asked them about the power steering leak and they said it was due to the power steering fluid being pushed back out of the reservoir, they said they weren't sure why but thought there was a recall on that. I hoping someone heard of this, or know what has to be done.
Old 09 May 2014, 10:24 pm
Recalls are for safety items - I would think they would know where the power steering fluid was going...
Engine light on / Power Steering issue? Artista General PT Cruiser Discussions 5 13 Jun 2013 04:47 pm
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
Inherited PT steering and alternator/battery probs lomodus General PT Cruiser Discussions 5 20 Dec 2011 11:00 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
