5 Chimes floowed by 1 long chime. No error code
  • 1 Post By CREWZIN
Old 06 May 2014, 05:00 pm
Default 5 Chimes floowed by 1 long chime. No error code
Can anyone help me out here? I do the key dance and get no code, but my car is dinging the chime 5 times followed by a pause and one long chime when I insert the key and start or even if I just put it to run.
Thanks!
Old 06 May 2014, 05:51 pm
Default Re: 5 Chimes floowed by 1 long chime. No error code
How about your owners manual? Does it tell you about the chimes? The chimes aren't faults so that's why your not seeing a fault code. The car is trying to tell you something. Key left in the ignition switch when the drivers door is open....seat belt not latched when you start the car....lights left on when you turn the ignition off.... turn signal left on to long. These are all conditions that the chime starts up.
mityqwik likes this.
Old 08 May 2014, 03:49 am
Thanks. Owner's manual had nothing that I could find, which is why I came on here. I never did find out what it was, but it has stopped, so I guess it's all good. Cheers!
Old 11 May 2014, 08:46 am
CREWZIN mentioned the seat belts in his post. Just tried on my '08 and starting the engine without seat belt fastened gets five chimes. Buckle up before engine start and it's all quiet.
Phill
The chimes whiteclaw General PT Cruiser Discussions 8 05 May 2012 08:29 pm
Long term P0301 error, newer P0522 SantaVaca Tech & Performance Forum 5 09 Aug 2011 04:32 pm
1684 code - how long til it clears itself? PTBluiser Tech & Performance Forum 19 20 Jul 2011 07:05 pm
Error Code bus b8 or 68, not sure. richardbradley Tech & Performance Forum 2 18 May 2010 07:45 pm
Error Code bds02pt Tech & Performance Forum 2 29 Jan 2010 03:01 pm
