Sputtering engine or slipping transmission
Old 09 May 2014, 10:44 pm
Exclamation Sputtering engine or slipping transmission
i have a problem. HELP!! as i was driving to work today i put my foot on the gas slightly and my car started to jerk a little bit. it only happens, so far, when i am lightly accelerating. any ideas on what this may be or how to fix it? thanks for your input.
Also, on the way home it happened, and was worse, under heavy acceleration. I am stumped.
Old 10 May 2014, 07:00 pm
Default Re: Sputtering engine or slipping transmission
So just took it to my closest Oreillys and they scanned it with no codes showing. my mother in law had a similar issue with her Pontiac torrent. Her issue was the plugs and plug wires. Next step is for me to try that. Unless you guys have any other ideas. Thanks.
Old 10 May 2014, 07:24 pm
Plugs and wires certainly can't hurt, and could well be your problem.
Old 12 May 2014, 08:20 pm
so new development!!!
i was heading back to work in the rain and my car dinged, the cel came on and now it won't go over 2k RPM. any ideas?
Old 12 May 2014, 08:31 pm
See if you have a code now....
How to retrieve fault codes.
Old 12 May 2014, 09:14 pm
i will after work. work the late shift at my job. i'll post the results after i do the "Key Dance"
Old 13 May 2014, 03:13 am
So after work I danced the key and got po339. Crankshaft position sensor. Never had to deal with this. I'm fairly mechanically inclined but is this something easy enough for me to fix? If so any idea jowl long it may take or how difficult it would be to complete?
Old 14 May 2014, 03:12 am
So I bought my sensor today. I haven't put it in yet. The code has me second guessing whether I should replace it or not. The code says crankshaft position sensor intermittent. What does that actually mean? Intermittently works, or intermittently not getting signal. Just not sure. Thanks guys.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 14 May 2014, 09:39 pm
Just an update. Started the work earlier today. Got young kids and not enough time to go straight through. I'll post a final update when all is said and done.
Old 15 May 2014, 02:27 am
All finished. So no longer getting a code,for now. But, now I have a strange squeak coming from the belt side of the motor. Any ideas what that may be. Btw huge pita for me to replace. Had to remove the rad fan to get enough room to get the bottom starter bolt out.
Transmission slipping when coming to a stop bottlerocket Tech & Performance Forum 14 06 May 2013 11:58 pm
Will a slipping, nonfunctioning transmission be covered under drivetrain warranty? Rumble Tech & Performance Forum 6 10 Oct 2011 11:10 pm
Engine Sputtering SaraT Tech & Performance Forum 5 28 May 2011 10:27 pm
Transmission Slipping-Told I need a new one for 4K..help! tolbin Tech & Performance Forum 8 04 Nov 2009 01:54 pm
2005 Slipping Transmission already Espresso General PT Cruiser Discussions 7 16 May 2005 08:37 am
