Check Engine light, only when stopped at red lights
Like Tree4Likes
Old 13 May 2014, 02:04 pm
Post Check Engine light, only when stopped at red lights
I have an 06 PT Cruiser basic model with 103K. The engine light came on and I took it the dealer to have it read. There was oil in one of the spark plugs.
I replaced all the valve gaskets, and the spark plugs. I put in 4 new Champions with 40 gaps. Cleaned the first cylinder of as much oil as I could.
The car runs much better, but I still have the light. It now only comes on when I'm stopped at red lights and in drive. No other time. I tried disconnecting the battery, but the light always comes back eventually.
There are no new codes.
Does anyone have an answer for me?
I have some theories:
1. I put the wrong gaps on the spark plugs.
2. the engine is still burning oil from the leaky gasket.
3. unrelated damage to fan or radiator of some kind.
4. need new hoses for the spark plugs as well.
Old 13 May 2014, 03:12 pm
Handy_Cruiser's Avatar
Default Re: Check Engine light, only when stopped at red lights
You said that there are no new codes. What are the codes that you do have?
rob342 likes this.
Old 13 May 2014, 06:02 pm
Ray_Dockrey's Avatar
How are you checking for codes? If doing the key dance codes may not show up. You need to have them read by somebody with a reader.
NitroPT likes this.
Old 13 May 2014, 06:28 pm
Vlefaive's Avatar
Maybe just consider avoiding red lights ?
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 13 May 2014, 06:34 pm
The gap of 0.040 is fine.
I think you should've replaced the spark plug wires as well.
NitroPT likes this.
Old 13 May 2014, 11:08 pm
That's a good point. I was just using my key. I'll try a reader. Any recommendations?
Old 14 May 2014, 07:22 am
I got P303, for spark plug 3. However, when I oped up the cover, I only found oil in plug 1.
Old 14 May 2014, 11:37 am
My mother in law had a fault in her car said the same thing. Her dealer just replaced the plugs and wires. So I would suggest trying that next.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 22 May 2014, 07:15 am
I replaced the plug wires and it does work better. Still, light is on.
I have a new theory: Do I just need to drive it out to reset the codes?
If it didn't blink when I'm at red lights, I would think that would be the answer.
Any suggestions?
Old 22 May 2014, 07:22 am
Other causes -
Intake gasket leaking
Injector clogged
low compression
Does it idle smoothly?
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check oil light goes on & off when stopped at light Triplecat2002 General Turbo Discussions 12 06 Oct 2013 03:45 pm
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Check engine light, lights flickering, backfiring HELP pbman Tech & Performance Forum 2 15 Dec 2010 11:36 pm
