how long does the fuel pump last?
Old 14 May 2014, 08:21 am
Default how long does the fuel pump last?
I have a 2003 Pt Cruiser 2.4 original with 102,973 miles and I was curious on how long can the fuel pump last? I have never let the car run below 1/4 of fuel ever in its life its always either on half or full tank. can it maybe last till 200k miles or more?
Old 14 May 2014, 08:31 am
Default Re: how long does the fuel pump last?
Basically because of the design low amp draw and how it is lubricated as long as water is not introduced in the system and you don't run on lower limits that can partially expose the pump to air it could last 15+years 200k miles or more.
Old 14 May 2014, 08:33 am
So basically I have been taking good care of my fuel pump and would last many more miles? I have never let the pump see air in the tank ever
Old 14 May 2014, 08:37 am
No one can predict when and if any part may fail. I might suggest that you check the condition of your battery and the cables. A problem with getting a good power supply can effect the reliability of any electrical component. Fuel pumps like most electrical motors like a good supply of amps!
Old 14 May 2014, 08:38 am
I replace the battery every 3 years and the cables at the same time, I know I spend alot for both but its worth it
Old 14 May 2014, 08:43 am
mine failed at 234k. -but i don't know what the previous owners habits were with keeping a decent level in the tank. i do know that i have no record of a fuel pump being replaced in the service records. the shop that always fixed the car has a whole folder on it.
Old 14 May 2014, 08:48 am
I replace the battery every 3 years and the cables at the same time, I know I spend a lot for both but its worth it
The time or amount spent is not an indicator of condition.
Old 14 May 2014, 08:49 am
well thanks for the quick answering, I was curious because usually that's the first thing that fails in the fuel system when reaching past 100k miles
New fuel pump, but now no fuel to front? bundixlake Tech & Performance Forum 14 21 Mar 2014 09:41 pm
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
How long does fuel system hold pressure? unioncreek Tech & Performance Forum 25 11 Aug 2012 10:42 am
Bad fuel pump? Jules88 Tech & Performance Forum 8 28 Jun 2012 10:11 am
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
