Replacing the fuel pump to solve issues
  • 1 Post By JoeX
Old 15 May 2014, 11:09 pm
Question Replacing the fuel pump to solve issues
Ok, 2003 PT non-turbo, 130,000 miles.
This car idles around 700-800 rpm, engine practically dies and idles really rough.
Changed the plugs and wires, doesn't help.
Cleaned throttle body and other parts connected to it.
I'm suspecting a clogged fuel filter, which means replacing the fuel pump since they're located inside the tank.
Is there a way to test the pump before having to drain and drop the tank to do this replacement? Do you think it's time to change the fuel filter after 130,000 miles anyway?
Thanks
Old 16 May 2014, 01:08 am
Default Re: Replacing the fuel pump to solve issues
You did not mention how the engines runs off idle?
To properly test the fuel system you would at least need a fuel pressure instrument.
Old 16 May 2014, 02:04 am
It's a dog when I take off from a stand still, I can literally put my foot to the floor and it won't move fast but it's slow to react and it lags but then kicks in.
Is there a schrader valve where I can hook up a pressure guage?
Thanks for the reply.
Old 16 May 2014, 06:59 am
rckstein's Avatar
A while back I had my '06 Touring Edition at the dealership for some other work, while they had it I had them do a fuel system pressure check. I saw the gauge set up while installed on my PT and I believe there is a quick disconnect at the firewall, on the passenger side where the steel line comes into the engine compartment, that they unplugged and hooked up their gauge set to. The gauge set up was two gauges, similar to HVAC work, and they could check the fuel pump pressure, then turn a couple of valves and also check to see if the injectors are holding pressure. They let the gauges set to check any bleed down from the injectors as well.
Old 16 May 2014, 08:56 am
Usually the symptoms are the opposite of these. Idle great and looses power on acceleration under load. Pressure check as Nitro said will confirm.
Put some Berryman's chemtool B-12 in the tank. Good stuff and can't hurt. May be a dirty injector.But kinda sounds like a timing issue. Belt ever done?
Old 16 May 2014, 09:22 am
Glad you said that.
I have never had a fuel pump go bad or a filter clog, but logically, fuel supply would be adequate at idle but choke off under acceleration with a clogged filter or a weak fuel pump.
Old 16 May 2014, 08:26 pm
NOTE: This happen to me several years back, with the same brand only a Neon. Picked it up cheap at the JY and got it towed home, it only needed a fuel pump, $35 at the local JY and it was up and running, but no power and it sounded like it was sucking a lot of air when you hit the pedal.. Fuel pressure was good, even while running , injectors were fireing. I happen to change the injectors from another car and bingo we were in business.. What happen was the steel band around the fuel pump rusted and the very fine bits of rust (Iron) passed through the so called filter, its just a fine mesh at the pickup, and stopped when they got to the injectors. When I pulled the injectors off the fill tube pipe some injectors were actually full to the top with very fine rust (Iron). That let enough gas through the rust to run smoothly but absolutly no power..
It ran like new after replacing the injectors. May be you can find a good used set off an old motor to try.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
New fuel pump, but now no fuel to front? bundixlake Tech & Performance Forum 14 21 Mar 2014 09:41 pm
2.4L 2001 - Replacing Water Pump timbogates Tech & Performance Forum 14 24 Apr 2013 02:55 am
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
Replacing the power steering pump on 2001 Jeserla General PT Cruiser Discussions 1 09 Mar 2011 10:02 am
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
