AC not blowing cold air.
Old 17 May 2014, 11:45 am
Default AC not blowing cold air.
I was having an issue with my ac not blowing cold. I put in new coolant hoping it would work, but it didn't. I did a lot of research and found the answer that has fixed it. I replaced the radiator fan assay. It cooled the car down but not enough to push the ac air. Below is where i got the part, works fantastic.
ReplaceŽ - Chrysler PT Cruiser 2006-2009 Dual Fan Assembly
This is the video that shows you how to remove/install it as well.
Old 17 May 2014, 12:21 pm
Default Re: AC not blowing cold air.
We've known about the fan issue for a long time. In our Tech & Performance section there's a thread entitled "HOW TO" and when opening that thread there's about 30 threads that tell you how to fix almost everything on the PT. I made a thread about 10 years ago on how to replace the fan when one or both speeds of the fan motor stop working because of the burnt out interior pieces.
There's also a thread that tells how to fix the motor itself if you care to.
HOW TO's
Air Conditioner Not Blowing Cold khantoll General PT Cruiser Discussions 25 31 Dec 2014 01:06 am
Air Conditioner not blowing cold air TryingToFixIt Feedback and Support 0 01 May 2013 09:52 am
Air conditioning is cold, but stops blowing Beej Tech & Performance Forum 9 13 Dec 2010 01:10 pm
A/C Not blowing as cold as it did before renshaw86 Tech & Performance Forum 6 05 Jun 2010 08:28 pm
A/C blowing warm then cold idling & overcharged!!! 66CUDA Tech & Performance Forum 65 05 Apr 2010 09:07 am
