wheels
Old 19 Nov 2002, 05:01 am
Default wheels
Hello. My PT is equipped with stock 16" wheels and 205/55/16.
if I mount 17" wheels , what tire size should I use ?
Old 19 Nov 2002, 08:33 am
Raphael,
What your looking to do is use a "Plus 1" tire/wheel upgrade. This keeps the diamiter of the tire on both the 16" and 17" the same. The "sidewall" measurement should go down a step as the wheel size goes up, so 45 is the recommended size for 17" wheels. The width of the tire is a personal choise. 215/225/235 will all fit in the wheel well. So what your looking for is: 215/45/17 or 225/45/17 or 235/45/17. The www.tirerack.com site goes right up to 235/45/17 when you type in a 17" wheel for a PT Cruiser.
Old 19 Nov 2002, 08:40 am
Do a search on "tire size calculator" on the WWW. A number of options will come up.
Here's just one:
http://www.dsm.org/tools/tiresize.htm
Puck
Old 19 Nov 2002, 09:29 am
tirerack.com shows in a 17 inch wheel to use a 235/45/17 to keep things right compared to the 16's that come on your car...this size is what I run and I have no troubles at all.
be cool, James <img src=icon_smile_big.gif border=0 align=middle>
Old 22 Nov 2002, 07:18 pm
tom tom is offline
hello I would like to use a 205 or 225 60 series tire in the back to get the street look probably a 15 inch to keep it the same dia. as my 205-55 16 up front. HAS ANY ONE TRIED THIS? THANKS Tom
Old 24 Nov 2002, 10:17 pm
Tom,
I went to 225/55 on 16" rims. Later swapped them for 215/60/16. They look and run great. But, I'm still exploring to find that ultimate hot rod look.
Good luck.
Old 25 Nov 2002, 06:13 pm
I replaced the stock 16" wheel/tire setup on the Limited with 17x8 Mille Miglia wheels and 235/45 x 17 Bridgestone Potenza 950s. Only problem is that the wider tires really do catch road irregularities. Based on that experience, I think I'll stick to the stock 17" tires when I get my new Dreamcruiser2 this spring.
17" Mille Miglia/Potenza RE-950s;HD sway bars/strut brace;H&R sprngs;Zenon cvrs;Bassani duals;Hot Rod Crsng grle;intake mods;gauge pod;more;Pix @ http://www.imagestation.com/album/in...?id=4292219387
Do "KLEEN WHEELS" really work??? Gary04GT Wheels, Tires, Suspension 15 12 Oct 2008 07:44 pm
Using bigger wheels lcuadrado Tech & Performance Forum 16 24 Jul 2007 01:06 pm
SRT-4 Wheels on the GT blueberrygt Turbo Wheels/Suspension/Handling 3 13 Apr 2004 06:45 pm
I don't like my new wheels coolvirus Turbo Wheels/Suspension/Handling 5 05 Mar 2004 06:14 pm
Lets talk Wheels turbomangt The Detail Shop 2 05 Feb 2004 02:10 am
