Cam sensor P0340 code question
Old 19 May 2014, 01:49 pm
Default Cam sensor P0340 code question
We are getting the P0340 code (cam sensor), but the car seems to be starting and running perfect. I checked the wires and they look fine, although I had to re-wrap them for protection. Can't get the code to clear.
I don't mind buying the sensor and I can install it, but there doesn't seem to be an actual running problem with the engine.
Thanks for any help.
Old 19 May 2014, 02:06 pm
Ray_Dockrey's Avatar
Default Re: Cam sensor P0340 code question
Mine did the same thing. It would go off and then come back on but it drove just fine. Then one day headed home things went south. The car went into limp mode but I was able to get it home. Replaced the sensor and all is well.
Old 19 May 2014, 02:14 pm
Thanks Ray...
Looks like I will head over to the dealer for a new sensor! I work out of town and don't want the wife to be broken down...
Thanks again
Old 19 May 2014, 03:20 pm
cruserdad1976's Avatar
at least have a spare one in case just to be safe
Old 19 May 2014, 04:12 pm
Might want to get a new Target Magnet while your at it. It's cheap and could save a problem down the road.
Camshaft sensor and P0340 cruiser_wa Tech & Performance Forum 3 31 Mar 2014 07:18 pm
Cam Sensor Problem?? P0340 mcupkim General PT Cruiser Discussions 17 20 Oct 2013 10:40 pm
P0340 cam sensor code in 2006 cruiser deighter Tech & Performance Forum 13 12 Jan 2012 07:41 am
Code P0340 Cam Shaft Position Sensor A Dsmsta187 General PT Cruiser Discussions 6 13 Apr 2010 09:01 pm
Code P0340 Cam Shaft Position Sensor A Leroy Western PT Forum 4 02 Apr 2010 04:01 pm
